Shelly devices 'announce' and 'update_fw'
Posted: Wednesday 15 December 2021 16:21
for those of you, who use a lot of shellies and may be not aware:
there's 2 endpoints in shelly devices for MQTT as stated in the title.
'announce' will give you a status update of all your shellies within your network, along with an indicator, if there is a firmware update (may not work for battery driven devices that are asleep).
'update_fw' will do exactly what it says
it is the easiest Node-Red flow ever:
"id": "f97b9afc9b8c3c01",
"type": "tab",
"label": "Flow 6",
"disabled": false,
"info": ""
"id": "3c61bc45b929e1dd",
"type": "inject",
"z": "f97b9afc9b8c3c01",
"name": "",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "announce",
"payloadType": "str",
"x": 150,
"y": 180,
"wires": [
"f4b27693b1e2a13d"
"id": "f4b27693b1e2a13d",
"type": "mqtt out",
"name": "",
"topic": "shellies/command",
"qos": "",
"retain": "",
"respTopic": "",
"contentType": "",
"userProps": "",
"correl": "",
"expiry": "",
"broker": "efc9f8538719bafa",
"x": 410,
"y": 180,
"wires": []
"id": "2dc591a421530271",
"type": "mqtt in",
"name": "",
"topic": "shellies/announce",
"qos": "2",
"datatype": "auto",
"nl": false,
"rap": true,
"rh": 0,
"x": 160,
"y": 260,
"wires": [
"362d77999649021d"
"id": "0177b987a4e90989",
"type": "debug",
"name": "",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "false",
"statusVal": "",
"statusType": "auto",
"x": 550,
"y": 260,
"wires": []
"id": "362d77999649021d",
"type": "json",
"name": "",
"property": "payload",
"action": "",
"pretty": false,
"x": 350,
"y": 260,
"wires": [
"0177b987a4e90989"
"id": "b022019d43adc03d",
"type": "inject",
"name": "update_fw",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "update_fw",
"x": 150,
"y": 120,
"wires": [
"f4b27693b1e2a13d"
"id": "efc9f8538719bafa",
"type": "mqtt-broker",
"name": "",
"broker": "192.168.2.40",
"port": "1883",
"clientid": "",
"usetls": false,
"protocolVersion": "4",
"keepalive": "60",
"cleansession": true,
"birthTopic": "",
"birthQos": "0",
"birthPayload": "",
"birthMsg": {},
"closeTopic": "",
"closeQos": "0",
"closePayload": "",
"closeMsg": {},
"willTopic": "",
"willQos": "0",
"willPayload": "",
"willMsg": {},
"sessionExpiry": ""
