Stop timer in lua
harrykausl
Domoticz version: 2021.1
Stop timer in lua
Post by harrykausl »
I track my TV with the system alive checker. When tv is started, I switch a wallplug with a chromecast to on. When tv is set to off, I switch the plug to off after 20 minutes. All is done in lua. When within the 20 minutes the tv is started again, I want to check, if there is a off-timer for the wallplug running and stop it. Is this possible in lua? If not, I have to create a dummy-switch to do the offset timing for the wallplug.
