Light script - Event detected but no effect
Posted: Friday 10 December 2021 21:09
by TomBoeg
Hello everyone,
I'm currently having some trouble with the dzvenst script i've written for my lights.
I'm using one selector switch to say if I want it all automated (Auto) or manually On or Off (5 levels in total).
Then I have two dummy light switch for the schedule (outdoor lights and indoor lights) to indicate if the lights should be switched On or Off depending on the day of the week and so on.
All modes are working except for the Auto : the lights are not switched On or Off according to the schedule (the dummy switch used for the schedule are going On and Off as planned).
Here is the code :
	active = true,
		devices = { 'Selecteur_Ambiance',
		            'Planning_Eclairage_Indoor',
		            'Planning_Eclairage_Outdoor'
	-- custom logging level for this script
	logging = {
        level = domoticz.LOG_DEBUG,
        marker = "Script Ambiance_lumineuse_v2"
	execute = function(domoticz, Selecteur_Ambiance, Planning_Eclairage_Indoor, Planning_Eclairage_Outdoor)
		if (Selecteur_Ambiance.levelName == 'Off_All') then -- Full Off
		    domoticz.devices('Lampe_Salle_a_Manger').switchOff()
		    domoticz.devices('Lampe_Entrée').switchOff()
		    domoticz.devices('Eclairage_Exterieur').switchOff()
		    domoticz.devices('Level_Lampe_Buffet').switchOff()
			domoticz.log('The lights are switched Off forever')
		if (Selecteur_Ambiance.levelName == 'On_All') then -- Full On
		    domoticz.devices('Lampe_Salle_a_Manger').switchOn()
		    domoticz.devices('Lampe_Entrée').switchOn()
		    domoticz.devices('Eclairage_Exterieur').switchOn()
		    domoticz.devices('Level_Lampe_Buffet').switchOn()
			domoticz.log('The lights are switched On forever')
		if (Selecteur_Ambiance.levelName == 'On_Once') then -- Set everything On once and then back to Auto at 23:59
		    Selecteur_Ambiance.switchSelector('Auto').at('23:59')
			domoticz.log('The lights are switched On and selector set on Auto')
		if (Selecteur_Ambiance.levelName == 'Off_Once') then -- Set everything Off once and then back to Auto at 23:59
			domoticz.log('The lights are switched Off and selector set on Auto')
		if (Selecteur_Ambiance.levelName == 'Auto' and Planning_Eclairage_Indoor.state == 'On') then -- Auto as per Planning_Eclairage_Indoor On
			domoticz.log('The lights are switched On (Auto Inside)')
		if (Selecteur_Ambiance.levelName == 'Auto' and Planning_Eclairage_Indoor.state == 'Off') then -- Auto as per Planning_Eclairage_Indoor Off
			domoticz.log('The lights are switched Off (Auto Inside)')
		if (Selecteur_Ambiance.levelName == 'Auto' and Planning_Eclairage_Outdoor.state == 'On') then -- Auto as per Planning_Eclairage_Outdoor On
			domoticz.log('The lights are switched On (Auto Outside)')
		if (Selecteur_Ambiance.levelName == 'Auto' and Planning_Eclairage_Outdoor.state == 'Off') then -- Auto as per Planning_Eclairage_Outdoor Off
			domoticz.log('The lights are switched Off (Auto Outside)')
And here is for example the log when the outdoor lights should be switched Off :
2021-12-09 21:00:00.585 Status: Starting automatic database backup procedure...
2021-12-09 21:00:01.585 Status: Schedule item started! Name: Planning_Eclairage_Outdoor, Type: On Time, DevID: 268, Time: 2021-12-09 21:00:01
2021-12-09 21:00:02.874 Planning_Eclairage_Outdoor: Light/Switch (Planning_Eclairage_Outdoor)
2021-12-09 21:00:02.862 Status: Ending automatic database backup procedure...
2021-12-09 21:00:03.053 Status: dzVents: Info: Handling events for: "Planning_Eclairage_Outdoor", value: "Off"
2021-12-09 21:00:03.053 Status: dzVents: Info: Script Ambiance_lumineuse_v2: ------ Start internal script: Ambiance_lumineuse_v2: Device: "Planning_Eclairage_Outdoor (Planning_Eclairage_Outdoor)", Index: 268
2021-12-09 21:00:03.054 Status: dzVents: Info: Script Ambiance_lumineuse_v2: ------ Finished Ambiance_lumineuse_v2
The event is detected but nothing happens...
I've tried as well a version with if/elseif but with the same results.
If anyone has an idea...
Thanks in advance for wour help
Thomas
Re: Light script - Event detected but no effect
Posted: Saturday 11 December 2021 0:35
by boum
Ugh, you've got some misunderstandings about the basics in dzvents.
Please read https://www.domoticz.com/wiki/DzVents:_ ... .80.A6_end
Especially, "The function has three parameters"
should be
The third parameter can be ignored. Since you trigger on devices, item will be the device that triggered the script. You can test it with
if item.name == "Selecteur_Ambiance" then
To access other devices, you should query the domoticz object (first parameter)
local Planning_Eclairage_Indoor = domoticz.devices("Planning_Eclairage_Indoor")
Hope this helps.
Posted: Sunday 12 December 2021 21:29
by TomBoeg
Hi boum,
Thank you for your message.
I've updated the code but I think that I'm still don't understanding something.
Here is what I came up with (short version for one of the combination only) but it's not working :
	active = true,
	logging = {
        marker = "Script Ambiance_lumineuse_v3"
    local Planning_Eclairage_Outdoor = domoticz.devices("Planning_Eclairage_Outdoor")
		if (item.name == "Selecteur_Ambiance" and item.levelName == 'Auto') and
		    (item.name == "Planning_Eclairage_Indoor" and item.state == 'Off') then -- Auto as per Planning_Eclairage_Indoor Off
Could you please help ?
Thanks in advance
Posted: Monday 13 December 2021 0:23
by boum
The problem is now boolean algebra. In your "if test" you check that item.name is both equal to Selecteur and Planning.
item is the triggered object. With each invocation of the script it can only be one of the triggers. "item" is what changed.
You would want:
	local Selecteur_Ambiance = domoticz.devices("Selecteur_Ambiance")
	if (Selecteur_Ambiance.levelName == 'Auto') and
Because you want to switch those indoor lights off when the Planning device is changed (and triggers the script), not when the selector is changed.
And this only when the selector state is on Auto.
In your case, your script might look like (using your first message as base):
	active = true,
	logging = {
		-- if the trigger is not the selector, only act if on Auto
		if item.name ~= 'Selecteur_Ambiance' then
		    	local selector = domoticz.devices("Selecteur_Ambiance")
			if selector.levelName == 'Auto' then
				-- table with item.name as index and an array of device names as values
				local commands = {
					Planning_Eclairage_Indoor = { 'Lampe_Salle_a_Manger', 'Lampe_Entrée', },
					Planning_Eclairage_Outdoor = { 'Eclairage_Exterieur', },
				domoticz.log('The lights are switched ' .. item.state .. ' (Auto ' .. item.name .. ')')
				local names = commands[ item.name ]
				for i,name in ipairs(names) do
					local device = domoticz.devices(name)
					if item.active then
						device.switchOn().checkFirst()
						device.switchOff().checkFirst()
			return -- early exit
		-- here we manage the change on the selector
		if (item.levelName == 'Off_All') then -- Full Off
		elseif (item.levelName == 'On_All') then -- Full On
		elseif (item.levelName == 'On_Once') then -- Set everything On once and then back to Auto at 23:59
		    item.switchSelector('Auto').at('23:59')
		elseif (item.levelName == 'Off_Once') then -- Set everything Off once and then back to Auto at 23:59
Edit: fix script
Posted: Monday 13 December 2021 21:40
by TomBoeg
Hi boum,
It's working well, thanks a lot for your explanation and the updated script !
Once you've explained the boolean algebra issue it was clear that it could not work :)
It will help me a lot for my future scripts
Thanks again
PS : there was a small typo mistake at line 29, the "s" was missing : local device = domoticz.devices(name) ;)
Posted: Monday 13 December 2021 22:21
by boum
Thanks Tom, I edited the code.
