EUR_SPIRITZ Wall Radiator Thermostat+ "Ignore start level"
- jursat
- Domoticz version: 2023.2
Can you explain to me what it means to ignore the start level
- JackD
Re: EUR_SPIRITZ Wall Radiator Thermostat+ "Ignore start level"
I have got those thermostats to......
If you believe the popup when hovering with the cursor over the settingsfield it states that it has something to do with the brightness of the display.
Thinks this is just a default translation, not got I clue what it is really for, I just run with "On", the way it was when I first installed these thermostats.
I am curios to, so your question +1
- radiator_termpos.jpg (199.55 KiB) Viewed 531 times
- jursat
I used to think it had something in common from the % of head opening
