Page 1 of 6
MQTT Audo-discovery
Posted: Thursday 02 December 2021 21:00
by sciurius
I am a bit confused by the information I can find on MQTT Auto-discovery. If I understand correctly, autodiscovery is now natively supported by Domoticz. However I can't seem to get it going.
I tries to manually add a device using some example code I found somewhere.
mosquitto_pub -t "homeassistant/binary_sensor/garden/config" -m '{"name": "garden", "device_class": "motion", "state_topic": "homeassistant/binary_sensor/garden/state"}'
According to MQTTExplorer the message is correctly received by the broker, but Domoticz doesn't respond.
Do I need to enable the autodetect in Domoticz first?
Re: MQTT Audo-discovery
Posted: Thursday 02 December 2021 21:42
by waltervl
Posted: Friday 03 December 2021 8:34
by sciurius
siklosi wrote: Thursday 02 December 2021 21:08
Auto Discovery Prefix should be
homeassistant. But this is only in new beta releases.
Thanks. Apparently auto-discovery is not in stable 2021.1.
Waiting for the next version, then...
Posted: Friday 03 December 2021 10:50
by waltervl
siklosi wrote: Friday 03 December 2021 10:09
When we are on the topic... what is correct procedure to reinitialize autodiscovery from z2m or domoticz in case when device was added to z2m but accept new hardware devices on domoticz was not enabled (aside from enabling accept new hardware devices
I would expect a trigger from the device (or perhaps some action in Z2M UI) would trigger a device creation in Domoticz.
Posted: Friday 03 December 2021 11:31
by waltervl
Perhaps a restart of the Domoticz MQTT gateway by clicking on the UPDATE button when selecting the MQTT Hardware from menu Setup - Hardware?
If you do not change anything on the hardware configuration the hardware will just restart after clicking on Update (not ADD!
Posted: Friday 03 December 2021 11:58
by heggink
This depends on your setitngs in zigbee/zwave2mqtt: in both cases you can specify whether to retain autodiscovery messages. If you do so, the last autodiscovery message is always kept bu the broker. Whenever you restart the hardware in domoticz, it will reload these and create missing devices if you accept new devices. The downside is that deleting devices requires you to manually delete these autodiscovery messages as well as, otherwise, already deleted devices will continue to be recreated.
You can also NOT retain these messages in which case restarting zwavejs/zigbee2mqtt will resend these autodiscovery messages on start. Typically, saving settings in zigbee2mqtt also does that.
I run both on my pi4 where I created a udev rule to restart the docker instance whenever the controller is removed/added. My aeotec gen5 stick is the one that does not work well with a pi4 reboot so I need to put a hub in between that hub occasionally disconnects/reconnects causing the docker instance to get stuck. The udev rule circumvents that by cathing the connect and restarting the docker instance when it does. It also then re-sends the autodiscovery messages.
So, multiple ways
Posted: Friday 03 December 2021 12:05
by waltervl
heggink wrote: Friday 03 December 2021 11:58
something to put in a wiki, best on Zigbee2MQTT page (
https://www.domoticz.com/wiki/Zigbee2MQ ... todiscover) and perhaps a new to be created ZwaveJS2MQTT page....
Posted: Friday 03 December 2021 16:07
by waltervl
waltervl wrote: Friday 03 December 2021 12:05
https://www.domoticz.com/wiki/ZwaveJS2MQTT wiki page created and ready to be modified by the community
Posted: Sunday 05 December 2021 9:49
by marcojpolet
What a coincidence, I',m also trying out the auto-discovery thing of MQTT integrated in Domoticz. It is working, but when the device sending the config item restarts, new devices are created. This is what I send:
homeassistant/switch/esp_blinds/Mqnas/config/': { "name": "Blind_1_Mqnas", "cmd_t" : "~/set", "stat_t" : "~/state" }
homeassistant/switch/esp_blinds/Mqnas/config/': { "name": "Blind_2_Mqnas", "cmd_t" : "~/set", "stat_t" : "~/state" }
The devices are created (2 switches named Blind_X_Mqnas), but the second start, a second pair of devices is created. They all have different ID values, but these seem to be auto-generated, not sent by me...
Any idea how to prevent this? Or is this just because it's still in beta?
Regards,
Marco
Posted: Sunday 05 December 2021 10:17
by jvdz
Marco,
Just add an uniq_id field to the payload as that is used for recognizing existing devices:
homeassistant/switch/esp_blinds/Mqnas/config/': { "name": "Blind_1_Mqnas", "cmd_t" : "~/set", "stat_t" : "~/state", "uniq_id":"your_unique_key_for_this_device" }
Jos
Posted: Sunday 05 December 2021 12:43
by marcojpolet
Thanks Jos! That was it! I already thought about the unique_id, but thought it needed to be in the /xx/xx/ path, not as an json item! It's working now!
Posted: Friday 10 December 2021 9:18
by marcojpolet
I know the Domoticz Auto-discovery is Beta, but is it working at least to a basic level? I can (as seen above) now succesfully add switches automatically, but when I try to turn them on from Domoticz, I get the following error:
Mosq: MQTT_Discovery: Invalid/Unhandled data received! (Topic: switch/Blind_1_Mqnas/set, Message: ON)
Mosq: my MQTT server
This is now my config topic:
homeassistant/switch/Blind_1_Mqnas/config': { "name":"Blind_1_Mqnas", "uniq_id":"Blind_1_Mqnas", "cmd_t":"homeassistant/switch/Blind_1_Mqnas/set", "stat_t":"homeassistant/switch/Blind_1_Mqnas/state" }
Any clue what I'm doing wrong?
Regards,
Marco
Posted: Friday 10 December 2021 13:49
by jvdz
Think the issue here is that you are using the HA discovery topic to send a status update which isn't supported.
So change your t_cmd to something else than
homeassistant/*
eg:
Topic: homeassistant/switch/Blind_1_Mqnas/config
Payload: { "name":"Blind_1_Mqnas", "uniq_id":"Blind_1_Mqnas", "cmd_t":"xx/switch/Blind_1_Mqnas/set", "stat_t":"xx/switch/Blind_1_Mqnas/state" }
And send the status update to Domoticz:
Topic: xx/switch/Blind_1_Mqnas/state
Payload: ON
Jos
Posted: Friday 10 December 2021 14:59
by marcojpolet
Thanks again Jos! That was it!!
Posted: Monday 20 December 2021 15:32
by rron
Hello Jos,
I' have the same problem but I don understand this solution. Can you explane where I change this?
Ronald
jvdz wrote: Friday 10 December 2021 13:49
homeassistant/*
eg:
Payload: ON
Jos
Posted: Monday 20 December 2021 15:34
by jvdz
rron wrote: Monday 20 December 2021 15:32
Hello Jos,
Ronald
Well, when you have the same issue, it means you are generating the CONFIG MQTT messages yourself, so that is where you need to change them.
Posted: Monday 20 December 2021 15:41
by rron
Well I think itś the same. My error looks like this:
2021-12-20 14:26:09.637 Error: MQTT: MQTT_Discovery: Invalid/Unhandled data received! (Topic: 18/38/0/currentValue, Message: {"time":1640003037730,"value":99,"nodeName":"Wasmachine","nodeLocation":"Zolder"})
2021-12-20 14:26:09.637 Error: MQTT: MQTT_Discovery: Something other then 'config' received on discovery topic! (23/38/1/currentValue/{"time":1639954365610,"value":0,"nodeName":"Kamer dimmer","nodeLocation":"Huiskamer"})!
2021-12-20 14:26:09.637 Error: MQTT: MQTT_Discovery: Invalid/Unhandled data received! (Topic: 23/38/1/currentValue, Message: {"time":1639954365610,"value":0,"nodeName":"Kamer dimmer","nodeLocation":"Huiskamer"})
2021-12-20 14:26:09.738 Error: MQTT: MQTT_Discovery: Something other then 'config' received on discovery topic! (23/38/2/currentValue/{"time":1639821438142,"value":99,"nodeName":"Kamer dimmer","nodeLocation":"Huiskamer"})!
2021-12-20 14:26:09.738 Error: MQTT: MQTT_Discovery: Invalid/Unhandled data received! (Topic: 23/38/2/currentValue, Message: {"time":1639821438142,"value":99,"nodeName":"Kamer dimmer","nodeLocation":"Huiskamer"})
jvdz wrote: Monday 20 December 2021 15:34
Hello Jos,
Ronald
Posted: Monday 20 December 2021 16:33
by jvdz
rron wrote: Monday 20 December 2021 15:41
No this looks different. You are getting updates for discovered devices that cause an error.
Can you share the CONFIG MQTT message for these devices so I can check?
Also: What is your MQTT discovery topic in Domoticz?
Posted: Monday 20 December 2021 17:23
by rron
jvdz wrote: Monday 20 December 2021 16:33
You have to help me out, just started this. You are meaning this?
![Image]()
- Schermafdruk van 2021-12-20 17-20-51.png (130.03 KiB) Viewed 7616 times
Posted: Monday 20 December 2021 17:35
by jvdz
You need to set the prefix the same at both sides, so change the domoticz prefix in ZWAVEJS2MQTT to homeassistant as well when that is what you have defined in domoticz/mqtt.
That topic prefix is used to exchange the device CONFIG topics & payload for auto discovery!
