Dear Domoticz friends,
I have recently bought ``badodo security TSM01 TKB z-wave 3 in 1 sensor``. The sensor is detected by Domoticz as `` TKB Home TSP01 3 in 1 PIR Motion Sensor. I use a ``Aeotec USB Z-WAVE Plus Controller Gen 5`` to communicate control the hardware.
It is a painful procedure to configure the 3 in 1 sensor. At some point during the configuration, I had 3 new devices in the device list: 1) Air Temperature, 2) Illuminance, and 3) switch. All devices were working at some point. However, after mounting the device to the door, only device 1) and 2) remained. The switch device automagically disappeared and did not return.
If I now, retry the installation, I found the following in the logs:
2021-12-01 13:09:07.291 Status: OpenZWave: Node Removed. HomeID: 4267099862, NodeID: 17 (0x11)
2021-12-01 13:09:12.324 OpenZWave: Value_Added: Node: 17 (0x11), CommandClass: BATTERY, Label: Battery Level, Instance: 1, Index: 0
2021-12-01 13:09:12.393 OpenZWave: Value_Added: Node: 17 (0x11), CommandClass: SENSOR MULTILEVEL, Label: Air Temperature, Instance: 1, Index: 1
2021-12-01 13:09:12.427 OpenZWave: Value_Added: Node: 17 (0x11), CommandClass: SENSOR MULTILEVEL, Label: Illuminance, Instance: 1, Index: 3
It seems that Instance:1, index: 2 is missing. Is this the missing switch device?
Does anyone have experience with using this multisensor within Domoticz? If yes, could you help me to get this device properly functioning? I would be very grateful.
B.t.w. I'm using Domoticz in a FreeBSD jail. I'm not sure whether this is important.
woffermans
- Target OS: -
