Page 1 of 2
Animated weather icons: May I have your votes please
Posted: Monday 29 November 2021 18:25
by Lokonli
As reported in another post the animated weather icons used in Dashticz result in quite some processor load.
whoami wrote: Saturday 27 November 2021 12:01
Further, I found a bug that leads to further increasing processor load over time.
The current animated weather icons within Dashticz make use of relatively old (?) technology (canvas block).
To reduce processor load two alternatives exist:
* SVG icons
* HTML/CSS
Examples of SVG icons:
https://bas.dev/projects/weather-icons
https://www.amcharts.com/free-animated- ... her-icons/
Examples of css/html based weather icons:
https://devsnap.me/css-weather-icons
For now, I think I will go for: https://bas.dev/projects/weather-icons
The picture above shows static, non-animated weather icons, because the forum doesn't support svg files. If you want to see animated versions click on one of the links.
Please let me know your preference this week. This weekend I'll remove the current animated weather icons, and replace them with the alternative solution that is having most votes.
Re: Animated weather icons: May I have your votes please
Posted: Monday 29 November 2021 18:32
by EdwinK
Posted: Monday 29 November 2021 19:22
by madpatrick
looking good !
I'll also go for : https://bas.dev/projects/weather-icons
Does it need any change in the blocks ?
Posted: Monday 29 November 2021 20:14
by epost
Posted: Monday 29 November 2021 20:37
by Krenstik
Posted: Monday 29 November 2021 22:02
by HansieNL
I like these icons: https://www.alessioatzeni.com/portfolio/meteocons/
Is it possible to have an option to use your own icons or make that things too complex?
Posted: Monday 29 November 2021 22:42
by Lokonli
Most votes for Bas.
First proto is working:
The icons are animated (but you can't see)
This are the line-icons. There is also set of filled icons.
I will check Alessio as well.
Posted: Monday 29 November 2021 22:50
by Lokonli
HansieNL wrote: Monday 29 November 2021 22:02 I like these icons: https://www.alessioatzeni.com/portfolio/meteocons/
This are static icons, but they are easy to add. I'll do that as well.
Posted: Sunday 05 December 2021 16:44
by Lokonli
I've just released 3.8.7
There is a new block parameter for the weatherblock: icons
Set this to 'line', 'fill', 'static' or 'meteo'.
The top 3 icon sets in the picture are dynamic icons (but you can't see in the static picture above)
Posted: Sunday 05 December 2021 17:49
by EdwinK
Like it
Posted: Monday 06 December 2021 10:41
by sammyke007
I like it a lot!
One request: is a static 'line' (with color) also an option please?
Posted: Monday 06 December 2021 12:24
by Lokonli
sammyke007 wrote: Monday 06 December 2021 10:41 I like it a lot!
You have to change the svg files a little. I don't have plans to do that, but you can do it yourself.
Create a new folder: ./custom/weathericons/linestatic
Copy all files from ./img/weathericons/line to ./custom/weathericons/linestatic
set the weather block parameter 'icons' to 'linestatic'
Open the svg files in the linestatic folder, and remove the transform part.
As an example, for 01d.svg (rotating sum) remove the following part to make it static:
<animateTransform attributeName="transform" dur="45s" from="0 32 32" repeatCount="indefinite" to="360 32 32" type="rotate"/>
You can also change colors if needed. The following part defines the color, which can be easily changed as well:
stroke="#f59e0b"
Enjoy :)
If more people ask for the static line icons, I'll add them as predefined set.
Posted: Monday 06 December 2021 13:14
by jake
I like it too.
The icons are quite a bit bigger than previous ones and therefore taking more real estate than is good for my layout. Can they be scaled through css? If so, how can this be done?
Posted: Monday 06 December 2021 13:54
by Lokonli
jake wrote: Monday 06 December 2021 13:14 I like it too.
See here for a temporarily fix:
viewtopic.php?p=283390#p283390
I'll make the icons somewhat smaller.
Posted: Monday 06 December 2021 17:21
by sammyke007
Lokonli wrote: Monday 06 December 2021 12:24
stroke="#f59e0b"
Enjoy :)
Already on it, but I'll have to continue with the last files later this evening. If you like, I can merge it to your branch after testing?
Posted: Monday 06 December 2021 18:56
by madpatrick
Lokonli wrote: Monday 06 December 2021 13:54
I like this size. If you ask me it much better
Posted: Monday 06 December 2021 20:09
by Lokonli
madpatrick wrote: Monday 06 December 2021 18:56
The big ones or the small ones? (I'm talking about the icons now)
Posted: Monday 06 December 2021 20:14
by madpatrick
Uhhhh. I think the big ones.
I didn’t change any setting, but did only the git update yesterday.
The icons were changed to the animated afterwards.
So, the default setting or default icons ?
How can i check this?
Posted: Sunday 12 December 2021 12:37
by whoami
stroke="#f59e0b"
Enjoy :)
Yes please, thank you for adjusting this.
Static coloured icons I would appreciate.
It still looks like the animated icons are still using a lot of cpu.
Do you see any improvements?
Posted: Sunday 12 December 2021 13:53
by sammyke007
Yeah, I'm using an "older" Huawei Mediapad T5 and static is a lot better instead of moving. It keeps lagging. Old tab, I know, but good enough for Dashzticz.
You can pull the latest beta, it contains the 'linestatic' option since 7/12/21.
