Ev1527 Learning Chinese devices
Posted: Monday 29 November 2021 12:30
by Dax1900
Hi there,
I bought a few RYC-JDQML001 switches on alibaba to be able to remotely switch on my smoke detectors alarm in all sleeping rooms. The smokedetectors are switched on by simply shortcutting the test button with the RYC-JDQML001 switch.
See: http://www.avunet.com:9080/attic/smokedetector_sw.jpg
According to the specs the RYC-JDQML001 switch supports EV1527 encoding. The problem is that I don't have the remote controller to control the RYC-JDQML001 switch. So I assume I can't use the learning mode in domoticz to add the JDQML001 switch. So I tried the manual mode but that didn't work:
Toevoegen handmatige Lamp/Schakelaar
Hardware: RFXCOM
Apparaat naam: SD-SW2
Schakelaar type: On/Off
Type: EV1527
ID: 01 03 09
Unit Code: 0
Testen
What am I doing wrong? Thanks for your tips and tricks!
(I hope I don't have to buy the remote because that takes weeks to arrive...)
