Regular error message when loading Dashticz dashboard
riko
Post by riko »
I have a problem with a regular error message when loading Dashticz.
I used to have a full and complexer dashboard, which I downsized to the basics only to get rid of this bug. Unfortunately removing most parts of the dashboard didn't help to solve this error. So I think the source might not be in my own code but somewhere else.
Is there anybody with experience in this field?
Lokonli
Re: Regular error message when loading Dashticz dashboard
Post by Lokonli »
I guess you are using Raspberry PI Buster and used automatic install.
Check here:
https://dashticz.readthedocs.io/en/beta ... l#solution
riko
Post by riko »
Your guess is correct about RPI Buster ;)
I'll check your tip later and report back
riko
Post by riko »
The solution perfectly works, thank you!
