Domoticz webserver crash after adding SmartVirtualThermostat hardware on stable Release 2021.1
Posted: Saturday 27 November 2021 17:46
I have installed a ne fresh release of Domoticz on a Rpi. Details of the releases below.
##########RASPBERRY####
Raspberry PI OS (32-bit)
A port of Debian with the Rpi Desktop (Release 2021-10-30)
##########DOMOTICZ####
Version: 2021.1 (stable version)
Build: 13191
Build Hash: 8547c5b7e
Compile Date: 2021-04-17 17:29:11
dzVents Version: 3.1.7
Python Version: 3.9.2 (default, Mar 12 2021, 04:06:34) [GCC 10.2.1 20210110]
After installing, the first thing i have done is to install the SmartVirtualThermostat. I did that, because i had this issue before after installing all my SmartHome systems.
Indeed, just after clicking on "ADD" Button in hardware section for this SMartVirtualThermostat plugin, the webserver crashes. If i uninstalled the SVT plugin, i can reach my webserver again.
I have read (some old post) that some update on BETA versions can solved the problems. However, i have tried it before making a new fresh installation without success.
I am adding the logs below it anyone as an idea, i will really appreciate
Thanks the team for the support
Build: 13191
pi@raspberrypi:~/domoticz $ ./domoticz
2021-11-27 17:14:07.013 Status: Domoticz V2021.1 (c)2012-2021 GizMoCuz
2021-11-27 17:14:07.013 Status: Build Hash: 8547c5b7e, Date: 2021-04-17 17:29:1 1
2021-11-27 17:14:07.013 Status: Startup Path: /home/pi/domoticz/
2021-11-27 17:14:07.304 Status: PluginSystem: Started, Python version '3.9.2'.
2021-11-27 17:14:07.312 Active notification Subsystems: fcm, http (2/13)
2021-11-27 17:14:07.315 Status: WebServer(HTTP) started on address: :: with por t 8080
2021-11-27 17:14:07.338 Error: WebServer(SSL) startup failed on address 0.0.0.0 with port: 443: bind: Permission denied
2021-11-27 17:14:07.338 Error: WebServer(SSL) check privileges for opening port s below 1024
2021-11-27 17:14:07.341 Starting shared server on: :::6144
2021-11-27 17:14:07.342 Status: TCPServer: shared server started...
2021-11-27 17:14:07.343 Status: RxQueue: queue worker started...
2021-11-27 17:14:09.344 Thermostat hardware started.
2021-11-27 17:14:09.344 Status: Thermostat: (Thermostat) Entering work loop.
2021-11-27 17:14:09.344 Status: Thermostat: (Thermostat) Started.
2021-11-27 17:14:09.345 Status: NotificationSystem: thread started...
2021-11-27 17:14:09.347 Status: EventSystem: reset all events...
2021-11-27 17:14:09.349 Status: EventSystem: reset all device statuses...
2021-11-27 17:14:09.545 Status: PluginSystem: 1 plugins started.
2021-11-27 17:14:09.613 Status: Python EventSystem: Initalizing event module.
2021-11-27 17:14:09.614 Status: EventSystem: Started
2021-11-27 17:14:09.615 Status: EventSystem: Queue thread started...
2021-11-27 17:14:10.373 Status: Thermostat: (Thermostat) Initialized version 0. 4.11, author 'logread'
2021-11-27 17:14:10.377 Thermostat: (Thermostat) Debug logging mask set to: NON E
2021-11-27 17:14:10.377 Status: Thermostat: (Thermostat) This version of domoti cz allows status logging by the plugin (in verbose mode)
Fatal Python error: Segmentation fault
Current thread 0x6ecff200 (most recent call first):
File "/home/pi/domoticz/plugins/SmartVirtualThermostat/plugin.py", line 142 in onStart
File "/home/pi/domoticz/plugins/SmartVirtualThermostat/plugin.py", line 619 in onStart
2021-11-27 17:14:10.379 Error: Domoticz(pid:3000, tid:3013('Thermostat')) recei ved fatal signal 11 (Segmentation fault)
2021-11-27 17:14:10.380 Error: siginfo address=0xbb8, address=(nil)
2021-11-27 17:14:15.383 Error: Did not find stack frame for thread (LWP 3013)), printing full gdb output:
2021-11-27 17:14:15.383 Error: > [New LWP 3001]
2021-11-27 17:14:15.383 Error: > [New LWP 3002]
2021-11-27 17:14:15.383 Error: > [New LWP 3003]
2021-11-27 17:14:15.383 Error: > [New LWP 3004]
2021-11-27 17:14:15.383 Error: > [New LWP 3005]
2021-11-27 17:14:15.383 Error: > [New LWP 3006]
2021-11-27 17:14:15.383 Error: > [New LWP 3007]
2021-11-27 17:14:15.383 Error: > [New LWP 3008]
2021-11-27 17:14:15.384 Error: > [New LWP 3009]
2021-11-27 17:14:15.384 Error: > [New LWP 3010]
2021-11-27 17:14:15.384 Error: > [New LWP 3011]
2021-11-27 17:14:15.384 Error: > [New LWP 3012]
2021-11-27 17:14:15.384 Error: > [New LWP 3013]
2021-11-27 17:14:15.384 Error: > [New LWP 3014]
2021-11-27 17:14:15.384 Error: > [New LWP 3015]
2021-11-27 17:14:15.384 Error: > [New LWP 3016]
2021-11-27 17:14:15.384 Error: > [New LWP 3017]
2021-11-27 17:14:15.384 Error: > [Thread debugging using libthread_db enabled]
2021-11-27 17:14:15.384 Error: > Using host libthread_db library "/lib/arm-linu x-gnueabihf/libthread_db.so.1".
2021-11-27 17:14:15.384 Error: > 0x76a87f8c in __GI___clock_nanosleep_time64 (c lock_id=clock_id@entry=0, flags=flags@entry=0, req=0x7e970218, req@entry=0x7e970 210, rem=0x7e970228, rem@entry=0x7e970220) at ../sysdeps/unix/sysv/linux/clock_n anosleep.c:52
2021-11-27 17:14:15.385 Error: > 52 ../sysdeps/unix/sysv/linux/clock_nanosle ep.c: No such file or directory.
2021-11-27 17:14:15.385 Error: > Id Target Id Frame
2021-11-27 17:14:15.385 Error: > * 1 Thread 0x76fdc040 (LWP 3000) "domoticz" 0x76a87f8c in __GI___clock_nanosleep_time64 (clock_id=clock_id@entry=0, flags=flags@entry=0, req=0x7e970218, req@entry=0x7e970210, rem=0x7e970228, rem@e ntry=0x7e970220) at ../sysdeps/unix/sysv/linux/clock_nanosleep.c:52
2021-11-27 17:14:15.385 Error: > 2 Thread 0x75a84200 (LWP 3001) "Watchdog" 0x76a87f8c in __GI___clock_nanosleep_time64 (clock_id=clock_id@entry=0, flags=flags@entry=0, req=0x75a83b70, req@entry=0x75a83b68, rem=0x75a83b80, rem@e ntry=0x75a83b78) at ../sysdeps/unix/sysv/linux/clock_nanosleep.c:52
2021-11-27 17:14:15.385 Error: > 3 Thread 0x75283200 (LWP 3002) "SQLHelper " syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
2021-11-27 17:14:15.385 Error: > 4 Thread 0x74a82200 (LWP 3003) "PluginMgr " syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
2021-11-27 17:14:15.385 Error: > 5 Thread 0x73c47200 (LWP 3004) "InfluxPus h" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
2021-11-27 17:14:15.385 Error: > 6 Thread 0x73446200 (LWP 3005) "Webem_ssn cleane" 0x76ac763c in epoll_wait (epfd=14, events=0x73445358, maxevents=128, tim eout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
2021-11-27 17:14:15.385 Error: > 7 Thread 0x72c45200 (LWP 3006) "WebServer _8080" 0x76ac763c in epoll_wait (epfd=10, events=0x72c44328, maxevents=128, tim eout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
2021-11-27 17:14:15.385 Error: > 8 Thread 0x722ff200 (LWP 3007) "Scheduler " syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
2021-11-27 17:14:15.385 Error: > 9 Thread 0x71afe200 (LWP 3008) "TCPServer " 0x76ac763c in epoll_wait (epfd=17, events=0x71afd358, maxevents=128, tim eout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
2021-11-27 17:14:15.385 Error: > 10 Thread 0x710ff200 (LWP 3009) "MainWorke r" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
2021-11-27 17:14:15.385 Error: > 11 Thread 0x708fe200 (LWP 3010) "MainWorke rRxMsg" futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0x708fd b80, clockid=<optimized out>, expected=0, futex_word=0xb229a0 <m_mainworker+3960 >) at ../sysdeps/nptl/futex-internal.h:323
2021-11-27 17:14:15.386 Error: > 12 Thread 0x6feff200 (LWP 3011) "WebServer _8080" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
2021-11-27 17:14:15.386 Error: > 13 Thread 0x6f6fe200 (LWP 3012) "WebServer _8080" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
2021-11-27 17:14:15.386 Error: > 14 Thread 0x6ecff200 (LWP 3013) "Thermosta t" 0x76a8e4d4 in __GI___wait4 (pid=3018, stat_loc=0x6e325580, options=0, us age=0x0) at ../sysdeps/unix/sysv/linux/wait4.c:27
2021-11-27 17:14:15.386 Error: > 15 Thread 0x6e2ff200 (LWP 3014) "Notificat ionSys" futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0x6e2fe bb0, clockid=<optimized out>, expected=0, futex_word=0xb22484 <m_mainworker+2652 >) at ../sysdeps/nptl/futex-internal.h:323
2021-11-27 17:14:15.386 Error: > 16 Thread 0x6d6ff200 (LWP 3015) "Plugin_AS IO" futex_wait_cancelable (private=0, expected=0, futex_word=0x1a309c8) at . ./sysdeps/nptl/futex-internal.h:186
2021-11-27 17:14:15.386 Error: > 17 Thread 0x6cefe200 (LWP 3016) "EventSyst em" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
2021-11-27 17:14:15.386 Error: > 18 Thread 0x6c6fd200 (LWP 3017) "EventSyst emQueu" futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0x6c6fc ac0, clockid=<optimized out>, expected=0, futex_word=0xb21b80 <m_mainworker+344> ) at ../sysdeps/nptl/futex-internal.h:323
2021-11-27 17:14:15.386 Error: > Thread 18 (Thread 0x6c6fd200 (LWP 3017) "Event SystemQueu"):
2021-11-27 17:14:15.386 Error: > #0 futex_abstimed_wait_cancelable (private=<o ptimized out>, abstime=0x6c6fcac0, clockid=<optimized out>, expected=0, futex_wo rd=0xb21b80 <m_mainworker+344>) at ../sysdeps/nptl/futex-internal.h:323
2021-11-27 17:14:15.386 Error: > #1 __pthread_cond_wait_common (abstime=0x6c6f cac0, clockid=<optimized out>, mutex=0x6c6fca60, cond=0xb21b58 <m_mainworker+304 >) at pthread_cond_wait.c:520
2021-11-27 17:14:15.387 Error: > #2 __pthread_cond_timedwait (cond=0xb21b58 <m _mainworker+304>, mutex=0x6c6fca60, abstime=0x6c6fcac0) at pthread_cond_wait.c:6 56
2021-11-27 17:14:15.387 Error: > #3 0x0020e0d0 in CEventSystem::EventQueueThre ad() ()
2021-11-27 17:14:15.387 Error: > #4 0x009a15a4 in execute_native_thread_routin e ()
2021-11-27 17:14:15.387 Error: > #5 0x76c03300 in start_thread (arg=0x6c6fd200 ) at pthread_create.c:477
2021-11-27 17:14:15.387 Error: > #6 0x76ac7208 in ?? () at ../sysdeps/unix/sys v/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2021-11-27 17:14:15.387 Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
2021-11-27 17:14:15.387 Error: > Thread 17 (Thread 0x6cefe200 (LWP 3016) "Event System"):
2021-11-27 17:14:15.387 Error: > #0 syscall () at ../sysdeps/unix/sysv/linux/a rm/syscall.S:37
2021-11-27 17:14:15.387 Error: > #1 0x0097f014 in std::__atomic_futex_unsigned _base::_M_futex_wait_until(unsigned int*, unsigned int, bool, std::chrono::durat ion<long long, std::ratio<1ll, 1ll> >, std::chrono::duration<long long, std::rat io<1ll, 1000000000ll> >) ()
2021-11-27 17:14:15.387 Error: > #2 0x002054b4 in CEventSystem::Do_Work() ()
2021-11-27 17:14:15.387 Error: > #3 0x009a15a4 in execute_native_thread_routin e ()
2021-11-27 17:14:15.387 Error: > #4 0x76c03300 in start_thread (arg=0x6cefe200 ) at pthread_create.c:477
2021-11-27 17:14:15.388 Error: > #5 0x76ac7208 in ?? () at ../sysdeps/unix/sys v/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2021-11-27 17:14:15.388 Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
2021-11-27 17:14:15.388 Error: > Thread 16 (Thread 0x6d6ff200 (LWP 3015) "Plugi n_ASIO"):
2021-11-27 17:14:15.388 Error: > #0 futex_wait_cancelable (private=0, expected =0, futex_word=0x1a309c8) at ../sysdeps/nptl/futex-internal.h:186
2021-11-27 17:14:15.388 Error: > #1 __pthread_cond_wait_common (abstime=0x0, c lockid=0, mutex=0x0, cond=0x1a309a0) at pthread_cond_wait.c:508
2021-11-27 17:14:15.388 Error: > #2 __pthread_cond_wait (cond=0x1a309a0, mutex =0x0) at pthread_cond_wait.c:638
2021-11-27 17:14:15.388 Error: > #3 0x003c7494 in boost::asio::detail::schedul er::run(boost::system::error_code&) ()
2021-11-27 17:14:15.388 Error: > #4 0x0064ca24 in Plugins::BoostWorkers() ()
2021-11-27 17:14:15.388 Error: > #5 0x008197bc in thread_proxy ()
2021-11-27 17:14:15.388 Error: > #6 0x76c03300 in start_thread (arg=0x6d6ff200 ) at pthread_create.c:477
2021-11-27 17:14:15.388 Error: > #7 0x76ac7208 in ?? () at ../sysdeps/unix/sys v/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2021-11-27 17:14:15.389 Error: > Thread 15 (Thread 0x6e2ff200 (LWP 3014) "Notif icationSys"):
2021-11-27 17:14:15.389 Error: > #0 futex_abstimed_wait_cancelable (private=<o ptimized out>, abstime=0x6e2febb0, clockid=<optimized out>, expected=0, futex_wo rd=0xb22484 <m_mainworker+2652>) at ../sysdeps/nptl/futex-internal.h:323
2021-11-27 17:14:15.389 Error: > #1 __pthread_cond_wait_common (abstime=0x6e2f ebb0, clockid=<optimized out>, mutex=0x6e2feb58, cond=0xb22458 <m_mainworker+260 8>) at pthread_cond_wait.c:520
2021-11-27 17:14:15.389 Error: > #2 __pthread_cond_timedwait (cond=0xb22458 <m _mainworker+2608>, mutex=0x6e2feb58, abstime=0x6e2febb0) at pthread_cond_wait.c: 656
2021-11-27 17:14:15.389 Error: > #3 0x00271270 in CNotificationSystem::QueueTh read() ()
2021-11-27 17:14:15.389 Error: > #4 0x009a15a4 in execute_native_thread_routin e ()
2021-11-27 17:14:15.389 Error: > #5 0x76c03300 in start_thread (arg=0x6e2ff200 ) at pthread_create.c:477
2021-11-27 17:14:15.389 Error: > #6 0x76ac7208 in ?? () at ../sysdeps/unix/sys v/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2021-11-27 17:14:15.389 Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
2021-11-27 17:14:15.389 Error: > Thread 14 (Thread 0x6ecff200 (LWP 3013) "Therm ostat"):
2021-11-27 17:14:15.390 Error: > #0 0x76a8e4d4 in __GI___wait4 (pid=3018, stat _loc=0x6e325580, options=0, usage=0x0) at ../sysdeps/unix/sysv/linux/wait4.c:27
2021-11-27 17:14:15.390 Error: > #1 0x0028b14c in dumpstack_gdb(bool) ()
2021-11-27 17:14:15.390 Error: > #2 0x0028b718 in signal_handler(int, siginfo_ t*, void*) ()
2021-11-27 17:14:15.390 Error: > #3 <signal handler called>
2021-11-27 17:14:15.390 Error: > #4 raise (sig=11) at ../sysdeps/unix/sysv/lin ux/raise.c:50
2021-11-27 17:14:15.390 Error: > #5 <signal handler called>
2021-11-27 17:14:15.390 Error: > #6 0x00000012 in ?? ()
2021-11-27 17:14:15.390 Error: > #7 0x75b0647c in _PyEval_EvalFrameDefault () from /lib/arm-linux-gnueabihf/libpython3.9.so
2021-11-27 17:14:15.390 Error: > #8 0x7004371c in ?? ()
2021-11-27 17:14:15.390 Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
2021-11-27 17:14:15.390 Error: > Thread 13 (Thread 0x6f6fe200 (LWP 3012) "WebSe rver_8080"):
2021-11-27 17:14:15.390 Error: > #0 syscall () at ../sysdeps/unix/sysv/linux/a rm/syscall.S:37
2021-11-27 17:14:15.391 Error: > #1 0x0097f014 in std::__atomic_futex_unsigned _base::_M_futex_wait_until(unsigned int*, unsigned int, bool, std::chrono::durat ion<long long, std::ratio<1ll, 1ll> >, std::chrono::duration<long long, std::rat io<1ll, 1000000000ll> >) ()
2021-11-27 17:14:15.391 Error: > #2 0x006f5034 in http::server::CWebsocketHand ler::Do_Work() ()
2021-11-27 17:14:15.391 Error: > #3 0x009a15a4 in execute_native_thread_routin e ()
2021-11-27 17:14:15.391 Error: > #4 0x76c03300 in start_thread (arg=0x6f6fe200 ) at pthread_create.c:477
2021-11-27 17:14:15.391 Error: > #5 0x76ac7208 in ?? () at ../sysdeps/unix/sys v/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2021-11-27 17:14:15.391 Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
2021-11-27 17:14:15.391 Error: > Thread 12 (Thread 0x6feff200 (LWP 3011) "WebSe rver_8080"):
2021-11-27 17:14:15.391 Error: > #0 syscall () at ../sysdeps/unix/sysv/linux/a rm/syscall.S:37
2021-11-27 17:14:15.392 Error: > #4 0x76c03300 in start_thread (arg=0x6feff200 ) at pthread_create.c:477
2021-11-27 17:14:15.392 Error: > #5 0x76ac7208 in ?? () at ../sysdeps/unix/sys v/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2021-11-27 17:14:15.392 Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
2021-11-27 17:14:15.392 Error: > Thread 11 (Thread 0x708fe200 (LWP 3010) "MainW orkerRxMsg"):
2021-11-27 17:14:15.392 Error: > #0 futex_abstimed_wait_cancelable (private=<o ptimized out>, abstime=0x708fdb80, clockid=<optimized out>, expected=0, futex_wo rd=0xb229a0 <m_mainworker+3960>) at ../sysdeps/nptl/futex-internal.h:323
2021-11-27 17:14:15.392 Error: > #1 __pthread_cond_wait_common (abstime=0x708f db80, clockid=<optimized out>, mutex=0x76bfea1c, cond=0xb22978 <m_mainworker+392 0>) at pthread_cond_wait.c:520
2021-11-27 17:14:15.392 Error: > #2 __pthread_cond_timedwait (cond=0xb22978 <m _mainworker+3920>, mutex=0x76bfea1c, abstime=0x708fdb80) at pthread_cond_wait.c: 656
2021-11-27 17:14:15.392 Error: > #3 0x0025d76c in MainWorker::Do_Work_On_Rx_Me ssages() ()
2021-11-27 17:14:15.392 Error: > #4 0x009a15a4 in execute_native_thread_routin e ()
2021-11-27 17:14:15.392 Error: > #5 0x76c03300 in start_thread (arg=0x708fe200 ) at pthread_create.c:477
2021-11-27 17:14:15.392 Error: > #6 0x76ac7208 in ?? () at ../sysdeps/unix/sys v/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2021-11-27 17:14:15.393 Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
2021-11-27 17:14:15.393 Error: > Thread 10 (Thread 0x710ff200 (LWP 3009) "MainW orker"):
2021-11-27 17:14:15.393 Error: > #0 syscall () at ../sysdeps/unix/sysv/linux/a rm/syscall.S:37
2021-11-27 17:14:15.393 Error: > #1 0x0097f014 in std::__atomic_futex_unsigned _base::_M_futex_wait_until(unsigned int*, unsigned int, bool, std::chrono::durat ion<long long, std::ratio<1ll, 1ll> >, std::chrono::duration<long long, std::rat io<1ll, 1000000000ll> >) ()
2021-11-27 17:14:15.393 Error: > #2 0x002595d0 in MainWorker::Do_Work() ()
2021-11-27 17:14:15.393 Error: > #3 0x009a15a4 in execute_native_thread_routin e ()
2021-11-27 17:14:15.393 Error: > #4 0x76c03300 in start_thread (arg=0x710ff200 ) at pthread_create.c:477
2021-11-27 17:14:15.393 Error: > #5 0x76ac7208 in ?? () at ../sysdeps/unix/sys v/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2021-11-27 17:14:15.393 Error: > Thread 9 (Thread 0x71afe200 (LWP 3008) "TCPSer ver"):
2021-11-27 17:14:15.393 Error: > #0 0x76ac763c in epoll_wait (epfd=17, events= 0x71afd358, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait. c:30
2021-11-27 17:14:15.393 Error: > #1 0x003c53b4 in boost::asio::detail::epoll_r eactor::run(long, boost::asio::detail::op_queue<boost::asio::detail::scheduler_o peration>&) ()
2021-11-27 17:14:15.394 Error: > #2 0x003c73ac in boost::asio::detail::schedul er::run(boost::system::error_code&) ()
2021-11-27 17:14:15.394 Error: > #3 0x006a2220 in std::thread::_State_impl<std ::thread::_Invoker<std::tuple<tcp::server::CTCPServer::StartServer(std::__cxx11: :basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std:: __cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const &)::{lambda()#1}> > >::_M_run() ()
2021-11-27 17:14:15.394 Error: > #4 0x009a15a4 in execute_native_thread_routin e ()
2021-11-27 17:14:15.394 Error: > #5 0x76c03300 in start_thread (arg=0x71afe200 ) at pthread_create.c:477
2021-11-27 17:14:15.394 Error: > #6 0x76ac7208 in ?? () at ../sysdeps/unix/sys v/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2021-11-27 17:14:15.394 Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
2021-11-27 17:14:15.394 Error: > Thread 8 (Thread 0x722ff200 (LWP 3007) "Schedu ler"):
2021-11-27 17:14:15.394 Error: > #0 syscall () at ../sysdeps/unix/sysv/linux/a rm/syscall.S:37
2021-11-27 17:14:15.395 Error: > #1 0x0097f014 in std::__atomic_futex_unsigned _base::_M_futex_wait_until(unsigned int*, unsigned int, bool, std::chrono::durat ion<long long, std::ratio<1ll, 1ll> >, std::chrono::duration<long long, std::rat io<1ll, 1000000000ll> >) ()
2021-11-27 17:14:15.395 Error: > #2 0x002825c0 in CScheduler::Do_Work() ()
2021-11-27 17:14:15.395 Error: > #3 0x009a15a4 in execute_native_thread_routin e ()
2021-11-27 17:14:15.395 Error: > #4 0x76c03300 in start_thread (arg=0x722ff200 ) at pthread_create.c:477
2021-11-27 17:14:15.395 Error: > #5 0x76ac7208 in ?? () at ../sysdeps/unix/sys v/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2021-11-27 17:14:15.395 Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
2021-11-27 17:14:15.395 Error: > Thread 7 (Thread 0x72c45200 (LWP 3006) "WebSer ver_8080"):
2021-11-27 17:14:15.395 Error: > #0 0x76ac763c in epoll_wait (epfd=10, events= 0x72c44328, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait. c:30
2021-11-27 17:14:15.395 Error: > #1 0x003c53b4 in boost::asio::detail::epoll_r eactor::run(long, boost::asio::detail::op_queue<boost::asio::detail::scheduler_o peration>&) ()
2021-11-27 17:14:15.395 Error: > #2 0x003c73ac in boost::asio::detail::schedul er::run(boost::system::error_code&) ()
2021-11-27 17:14:15.395 Error: > #3 0x006ed098 in http::server::server_base::r un() ()
2021-11-27 17:14:15.396 Error: > #4 0x002d2664 in std::thread::_State_impl<std ::thread::_Invoker<std::tuple<http::server::CWebServer::StartServer(http::server ::server_settings&, std::__cxx11::basic_string<char, std::char_traits<char>, std ::allocator<char> > const&, bool)::{lambda()#278}> > >::_M_run() ()
2021-11-27 17:14:15.396 Error: > #5 0x009a15a4 in execute_native_thread_routin e ()
2021-11-27 17:14:15.396 Error: > #6 0x76c03300 in start_thread (arg=0x72c45200 ) at pthread_create.c:477
2021-11-27 17:14:15.396 Error: > #7 0x76ac7208 in ?? () at ../sysdeps/unix/sys v/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2021-11-27 17:14:15.396 Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
2021-11-27 17:14:15.396 Error: > Thread 6 (Thread 0x73446200 (LWP 3005) "Webem_ ssncleane"):
2021-11-27 17:14:15.396 Error: > #0 0x76ac763c in epoll_wait (epfd=14, events= 0x73445358, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait. c:30
2021-11-27 17:14:15.396 Error: > #1 0x003c53b4 in boost::asio::detail::epoll_r eactor::run(long, boost::asio::detail::op_queue<boost::asio::detail::scheduler_o peration>&) ()
2021-11-27 17:14:15.396 Error: > #2 0x003c73ac in boost::asio::detail::schedul er::run(boost::system::error_code&) ()
2021-11-27 17:14:15.396 Error: > #3 0x006bd5e0 in std::thread::_State_impl<std ::thread::_Invoker<std::tuple<http::server::cWebem::cWebem(http::server::server_ settings const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::a llocator<char> > const&)::{lambda()#2}> > >::_M_run() ()
2021-11-27 17:14:15.396 Error: > #4 0x009a15a4 in execute_native_thread_routin e ()
2021-11-27 17:14:15.397 Error: > #5 0x76c03300 in start_thread (arg=0x73446200 ) at pthread_create.c:477
2021-11-27 17:14:15.397 Error: > #6 0x76ac7208 in ?? () at ../sysdeps/unix/sys v/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2021-11-27 17:14:15.397 Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
2021-11-27 17:14:15.397 Error: > Thread 5 (Thread 0x73c47200 (LWP 3004) "Influx Push"):
2021-11-27 17:14:15.397 Error: > #0 syscall () at ../sysdeps/unix/sysv/linux/a rm/syscall.S:37
2021-11-27 17:14:15.397 Error: > #1 0x0097f014 in std::__atomic_futex_unsigned _base::_M_futex_wait_until(unsigned int*, unsigned int, bool, std::chrono::durat ion<long long, std::ratio<1ll, 1ll> >, std::chrono::duration<long long, std::rat io<1ll, 1000000000ll> >) ()
2021-11-27 17:14:15.397 Error: > #2 0x00384634 in CInfluxPush::Do_Work() ()
2021-11-27 17:14:15.397 Error: > #3 0x009a15a4 in execute_native_thread_routin e ()
2021-11-27 17:14:15.397 Error: > #4 0x76c03300 in start_thread (arg=0x73c47200 ) at pthread_create.c:477
2021-11-27 17:14:15.397 Error: > #5 0x76ac7208 in ?? () at ../sysdeps/unix/sys v/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2021-11-27 17:14:15.397 Error: > Thread 4 (Thread 0x74a82200 (LWP 3003) "Plugin Mgr"):
2021-11-27 17:14:15.398 Error: > #0 syscall () at ../sysdeps/unix/sysv/linux/a rm/syscall.S:37
2021-11-27 17:14:15.398 Error: > #1 0x0097f014 in std::__atomic_futex_unsigned _base::_M_futex_wait_until(unsigned int*, unsigned int, bool, std::chrono::durat ion<long long, std::ratio<1ll, 1ll> >, std::chrono::duration<long long, std::rat io<1ll, 1000000000ll> >) ()
2021-11-27 17:14:15.398 Error: > #2 0x0064d114 in Plugins::CPluginSystem::Do_W ork() ()
2021-11-27 17:14:15.398 Error: > #3 0x009a15a4 in execute_native_thread_routin e ()
2021-11-27 17:14:15.398 Error: > #4 0x76c03300 in start_thread (arg=0x74a82200 ) at pthread_create.c:477
2021-11-27 17:14:15.398 Error: > #5 0x76ac7208 in ?? () at ../sysdeps/unix/sys v/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2021-11-27 17:14:15.398 Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
2021-11-27 17:14:15.398 Error: > Thread 3 (Thread 0x75283200 (LWP 3002) "SQLHel per"):
2021-11-27 17:14:15.398 Error: > #2 0x002a31ac in CSQLHelper::Do_Work() ()
2021-11-27 17:14:15.399 Error: > #3 0x009a15a4 in execute_native_thread_routin e ()
2021-11-27 17:14:15.399 Error: > #4 0x76c03300 in start_thread (arg=0x75283200 ) at pthread_create.c:477
2021-11-27 17:14:15.399 Error: > #5 0x76ac7208 in ?? () at ../sysdeps/unix/sys v/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2021-11-27 17:14:15.399 Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
2021-11-27 17:14:15.399 Error: > Thread 2 (Thread 0x75a84200 (LWP 3001) "Watchd og"):
2021-11-27 17:14:15.399 Error: > #0 0x76a87f8c in __GI___clock_nanosleep_time6 4 (clock_id=clock_id@entry=0, flags=flags@entry=0, req=0x75a83b70, req@entry=0x7 5a83b68, rem=0x75a83b80, rem@entry=0x75a83b78) at ../sysdeps/unix/sysv/linux/clo ck_nanosleep.c:52
2021-11-27 17:14:15.399 Error: > #1 0x76a88080 in __GI___clock_nanosleep (cloc k_id=clock_id@entry=0, flags=flags@entry=0, req=<optimized out>, rem=0x75a83bb0) at ../sysdeps/unix/sysv/linux/clock_nanosleep.c:92
2021-11-27 17:14:15.399 Error: > #2 0x76a8e830 in __GI___nanosleep (requested_ time=<optimized out>, remaining=<optimized out>) at nanosleep.c:27
2021-11-27 17:14:15.399 Error: > #3 0x0021f744 in sleep_milliseconds(long) ()
2021-11-27 17:14:15.399 Error: > #4 0x0028b880 in Do_Watchdog_Work() ()
2021-11-27 17:14:15.399 Error: > #5 0x009a15a4 in execute_native_thread_routin e ()
2021-11-27 17:14:15.400 Error: > #6 0x76c03300 in start_thread (arg=0x75a84200 ) at pthread_create.c:477
2021-11-27 17:14:15.400 Error: > #7 0x76ac7208 in ?? () at ../sysdeps/unix/sys v/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2021-11-27 17:14:15.400 Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
2021-11-27 17:14:15.400 Error: > Thread 1 (Thread 0x76fdc040 (LWP 3000) "domoti cz"):
2021-11-27 17:14:15.400 Error: > #0 0x76a87f8c in __GI___clock_nanosleep_time6 4 (clock_id=clock_id@entry=0, flags=flags@entry=0, req=0x7e970218, req@entry=0x7 e970210, rem=0x7e970228, rem@entry=0x7e970220) at ../sysdeps/unix/sysv/linux/clo ck_nanosleep.c:52
2021-11-27 17:14:15.400 Error: > #1 0x76a88080 in __GI___clock_nanosleep (cloc k_id=clock_id@entry=0, flags=flags@entry=0, req=<optimized out>, rem=0x7e970258) at ../sysdeps/unix/sysv/linux/clock_nanosleep.c:92
2021-11-27 17:14:15.400 Error: > #2 0x76a8e830 in __GI___nanosleep (requested_ time=<optimized out>, remaining=<optimized out>) at nanosleep.c:27
2021-11-27 17:14:15.400 Error: > #3 0x0021f6b0 in sleep_seconds(long) ()
2021-11-27 17:14:15.400 Error: > #4 0x001af338 in main ()
2021-11-27 17:14:15.400 Error: > Main thread:
2021-11-27 17:14:15.401 Error: > #1 0x76a88080 in __GI___clock_nanosleep (cloc k_id=clock_id@entry=0, flags=flags@entry=0, req=<optimized out>, rem=0x7e970258) at ../sysdeps/unix/sysv/linux/clock_nanosleep.c:92
2021-11-27 17:14:15.401 Error: > #2 0x76a8e830 in __GI___nanosleep (requested_ time=<optimized out>, remaining=<optimized out>) at nanosleep.c:27
2021-11-27 17:14:15.401 Error: > #3 0x0021f6b0 in sleep_seconds(long) ()
2021-11-27 17:14:15.401 Error: > #4 0x001af338 in main ()
2021-11-27 17:14:15.401 Error: > [Inferior 1 (process 3000) detached]
Segmentation fault
