OZWC MultiInstance Encapsulated dropped
Ragdag
Post by Ragdag »
I have multiple nodes in my OZWC that keep getting the following error.
2021-11-22 03:38:03.845 Error, Node020, ERROR: Dropping command, expected response not received after 1 attempt(s). Command: "MultiChannel Encapsulated (instance=1): MeterCmd_Get (Node=20): 0x01, 0x0e, 0x00, 0x13, 0x14, 0x07, 0x60, 0x0d, 0x01, 0x01, 0x32, 0x01, 0x10, 0x25, 0xdb, 0x41"
2021-11-22 03:38:03.848 Always,
2021-11-22 03:38:03.848 Always, Dumping queued log messages
2021-11-22 03:38:03.848 Always, End of queued log message dump
2021-11-22 03:38:54.729 Error, Node026, ERROR: Dropping command, expected response not received after 1 attempt(s). Command: "MultiInstance Encapsulated (instance=2): SwitchMultilevelCmd_Get (Node=26): 0x01, 0x0c, 0x00, 0x13, 0x1a, 0x05, 0x60, 0x06, 0x02, 0x26, 0x02, 0x25, 0xff, 0x65"
2021-11-22 03:38:54.731 Always,
2021-11-22 03:38:54.731 Always, Dumping queued log messages
2021-11-22 03:38:54.732 Always, End of queued log message dump
2021-11-22 03:43:29.671 Error, Node026, ERROR: Dropping command, expected response not received after 1 attempt(s). Command: "MultiInstance Encapsulated (instance=2): SwitchMultilevelCmd_Get (Node=26): 0x01, 0x0c, 0x00, 0x13, 0x1a, 0x05, 0x60, 0x06, 0x02, 0x26, 0x02, 0x25, 0xf2, 0x68"
2021-11-22 03:43:29.674 Always,
2021-11-22 03:43:29.674 Always, Dumping queued log messages
2021-11-22 03:43:29.674 Always, End of queued log message dump
2021-11-22 03:48:19.198 Error, Node026, ERROR: Dropping command, expected response not received after 1 attempt(s). Command: "MultiInstance Encapsulated (instance=2): SwitchMultilevelCmd_Get (Node=26): 0x01, 0x0c, 0x00, 0x13, 0x1a, 0x05, 0x60, 0x06, 0x02, 0x26, 0x02, 0x25, 0xee, 0x74"
2021-11-22 03:48:19.205 Always,
2021-11-22 03:48:19.205 Always, Dumping queued log messages
2021-11-22 03:48:19.205 Always, End of queued log message dump
2021-11-22 03:50:23.699 Error, Node047, ERROR: Dropping command, expected response not received after 1 attempt(s). Command: "MultiChannel Encapsulated (instance=2): MeterCmd_Get (Node=47): 0x01, 0x0e, 0x00, 0x13, 0x2f, 0x07, 0x60, 0x0d, 0x01, 0x01, 0x32, 0x01, 0x10, 0x25, 0x5b, 0xfa"
2021-11-22 03:50:23.701 Always,
I've seen a different post on the forum, but in that instance there were additional Group associations.
dheuts
Re: OZWC MultiInstance Encapsulated dropped
Post by dheuts »
I'm having the same problem. Since a couple of days, some battery powered Zwave nodes are responding very slow. It takes up to 7 seconds before the action is visible in Domoticz. With the same errors:
ERROR: Dropping command, expected response not received after 1 attempt(s). Command: "SwitchAllCmd_Get
and
ERROR: Dropping command, expected response not received after 1 attempt(s). Command: "PowerlevelCmd_Get
I see these message for different nodes.
Any idea how to solve this? I already tried restarting and healing the network.
Raspberry Pi 4 With Domoticz - RFXCom - Tuya Wifi LED lights - Chuango Alarm - Zwave+ - Zigbee2MQTT - Anna Thermostat - Broadlink IR, P1 - Eufy Robo Vacuum - Worx Robo Mower
mgugu
Post by mgugu »
Could be an interference problem, please try to follow these rules:
- Do not connect the stick directly to the Pi
- Instead put a 50cm-1m usb cable between, with the stick as high as possible an far from other electronic devices.
Rules also apply to zigbee
