Update sValue without notify
Renber
Post by Renber »
Hello, Is there a way with Dzvents to update the "rawdata" or "sValue" without sending a notification?
Thank you
Linux Debian 12 Server: Domoticz beta + Dashticz beta + Node-Red + Homebridge
Domoticz version: 2025.1
Re: Update sValue without notify
Use .updateQuiet(nValue, sValue)
Could also be that below function is working for you:
etValues(nValue,[ sValue1, sValue2, …]):
Function. Generic .salternative method to update device nValue, sValues. Uses domoticz JSON API to force subsequent pushes like influxdb and MQTT. nValue required but when set to nil it defaults to current nValue. sValue parms are optional and can be many. 3.0.8 If one of sValue parms is ‘parsetrigger’, subsequent eventscripts will be triggered.
Renber
Post by Renber »
Thanks for your reply but this command sends a notification and updates the history.
hoeby
Domoticz version: V2022.1
Post by hoeby »
waltervl wrote: Saturday 20 November 2021 7:44 Use .updateQuiet(nValue, sValue)
I saw this thread, and have read what you have written.
Have i understand it correct, when sending this json. The device is update but state keeps the same?
http://192.168.xxx.xxx:8080/json.htm?ty ... nvalue=nil
I tried it, but i am doing something wrong.
I switch a device On then fired the json line. The device goes Off
Was my json line correct or what is the correct line to update only the last seen time without changing switch state and do no triggers?
Renber
Post by Renber »
Your order doesn't work with me either. He takes the 'nile' for a '0'.
Maybe you will find a solution with Dzvents and the command dz.devices (idx) .Touch ()
Normally it updates the lastupdate without writing anything to the database.
Otherwise to date I haven't found any way to refresh svalue without triggering a history write and without notification.
An idea ?
hoeby
Post by hoeby »
Triggering without write in history or notificaties could be done with &parsetrigger=false
Thanks for you answer, but dz.devices(idx).Touch() isn't going to work. I need a mqtt command (prefer), to get it done from nodered
Renber
Post by Renber »
does not work either, I still receive notifications
jacobsentertainment
Domoticz version: 2021-1
Post by jacobsentertainment »
Renber wrote: Saturday 20 November 2021 7:28 Hello, Is there a way with Dzvents to update the "rawdata" or "sValue" without sending a notification?
ce
Thank you
Not sure what the idea is but correct me if I'm wrong, you want to update without knowing there is a update :?
You have some script running that sends a notification on update, why not turn it around and only send a notification on specific condition!
