Tip for failing 433Mhz movement sensor
Posted: Friday 19 November 2021 17:25
In my house there are several cheap chinese movement-sensors for switching on lights. Today I had to change batteries of one of them.
After I did the sensor was not recognized any longer. Using the RFXmanager I found that the sensor gave UNDEC type of protocol i.e. unknown.
I tried several other sensors/batteries. At long last I found that the queality of the battery-used caused the problem. I used knew low-cost batteries which gave failures. After I used the wellknown high quality batteries all was Oke again (protocol Lighting4).
Lessons learnt: even if measuring of a battery gives right voltage it is not a guarantee the sensor works as expected.
Hopefully I help others with my experience (which in fact took to much time
-Bart
-Bart
