fibaro double switch
Posted: Wednesday 17 November 2021 11:36
i use domotics Compile Date: 2021-04-17 17:29:11 with an double switch of fibaro.
The zwave connection are ok, when i send a singnal to the switch -> switch on
in log i see the command to the switch, but the switch don´t switch the lamp.
When i switch directly on the fibaro, the little taste...then switch the light on or off, in domotics the command change the status correctly
Have somebody an ideo, why the command goes to switch, but the switch don´t work.
regards
regards
