Problems with graph
darrepac
Problems with graph
Post by darrepac »
Hello
I have 2 graphs and 2 problems :roll:
I am fighting since several hours without success...
2021-11-15 15_21_45-WhatsApp.png (333.25 KiB) Viewed 957 times
For the graph on the left, I don't understand why I don't have the legend at the bottom.
See my code:
//Graph Temp
blocks ['Graph Temp'] = {
	title: 'Températures',
        devices: [37, 81, 41, 38],
	graphTypes: ['te'],
	width: 12,
        graph: ['line', 'line', 'line', 'line'],
        custom: {
        "Dernières heures": {
                range: 'last hours',
                data: {
                        Maison: 'd.te_37',
                        Moyenne: 'd.te_81',
			AirPulsé: 'd.te_41',
			Extèrieur: 'd.te_38',
        "Dernières 24h":{
                range: 'day',
                 data: {
                        Maison: 'd.te_37',
                        Moyenne: 'd.te_81',
        "Mois":{
                range: 'month',
                 data: {
                        Maison: 'd.te_37',
                        Moyenne: 'd.te_81',
	legend: {
		'te_37': 'Maison',
		'te_81': 'Moyenne',
		'te_41': 'Air Pulsé',
		'te_38': 'Extèrieur'
On the right, the graph simply disappear when I introduced the one on the left :!: :?:
//Graph Elec
blocks ['Graph Elec'] = {
	title: 'Consommation',
	devices: [34, 157],
	graph: ['bar', 'bar', 'bar'],
	legend: true,
	width: 12,
	custom: {
		data: {
			Linky: 'd.v_34',
			Solaire: 'd.v_157',
	"Dernières 24h":{
		range: 'day',
		 data: {
                        Linky: 'd.v_34',
                        Solaire: 'd.v_157',
        "Mois":{
                range: 'month',
                 data: {
                        Linky: 'd.v_34',
                        Solaire: 'd.v_157',
2021-11-15 15_16_44-WhatsApp.png (94.93 KiB) Viewed 957 times
Lokonli
Re: Problems with graph
Post by Lokonli »
darrepac wrote: Monday 15 November 2021 15:24 Hello
See my code:
//Graph Temp
	graphTypes: ['te'],
	width: 12,
        custom: {
                data: {
                        Maison: 'd.te_37',
                        Moyenne: 'd.te_81',
        "Dernières 24h":{
                range: 'day',
                 data: {
                        Maison: 'd.te_37',
                        Moyenne: 'd.te_81',
        "Mois":{
                range: 'month',
                 data: {
                        Maison: 'd.te_37',
                        Moyenne: 'd.te_81',
	legend: {
		'te_37': 'Maison',
		'te_81': 'Moyenne',
//Graph Elec
	devices: [34, 157],
	legend: true,
	width: 12,
	custom: {
		data: {
			Linky: 'd.v_34',
			Solaire: 'd.v_157',
	"Dernières 24h":{
		range: 'day',
		 data: {
                        Linky: 'd.v_34',
                        Solaire: 'd.v_157',
        "Mois":{
                range: 'month',
                 data: {
                        Linky: 'd.v_34',
                        Solaire: 'd.v_157',
For the first one:
the legend is defined on the wrong position. It's now defined as a data series.
Further, don't define a legend for custom graphs. If you want to show the legend, just add legend:true.
Try the following:
//Graph Temp
	graphTypes: ['te'],
	width: 12,
        custom: {
                data: {
                        Maison: 'd.te_37',
                        Moyenne: 'd.te_81',
        "Dernières 24h":{
                range: 'day',
                 data: {
                        Maison: 'd.te_37',
                        Moyenne: 'd.te_81',
        "Mois":{
                range: 'month',
                 data: {
                        Maison: 'd.te_37',
                        Moyenne: 'd.te_81',
	legend: true
darrepac
Post by darrepac »
ok thanks, the problem for the left graph is solved!
The problem for the left, remain
TapNL
Post by TapNL »
@darepac.
I really like your icons, can you point me in a direction where I can find them and install them?
Thx in advance.
darrepac
Post by darrepac »
TapNL wrote: Monday 15 November 2021 18:55 @darepac.
Thx in advance.
Which icons? I am using standard dial feature
TapNL
Post by TapNL »
I was not aware of the dial feature.
Did not update layout of my dashboard for a while. Will have a look at it. Thx!
darrepac
Post by darrepac »
@lonkoli I still cannot make the graph on the right to work... in the console, I have the following:
bundle.js?t=18:309 jQuery.Deferred exception: Cannot set properties of undefined (setting 'type') TypeError: Cannot set properties of undefined (setting 'type')
    at js/components/graph.js:809:49
    at Array.forEach (<anonymous>)
    at createGraph (js/components/graph.js:808:25)
    at Array.<anonymous> (js/components/graph.js:381:5)
    at mightThrow (http://192.168.0.61:8082/dist/bundle.js?t=18:309:28164)
    at R (http://192.168.0.61:8082/dist/bundle.js?t=18:309:28545) undefined
darrepac
Post by darrepac »
Found it , it was this line:
should be
graph: ['bar', 'bar'],
Lokonli
Post by Lokonli »
darrepac wrote: Thursday 18 November 2021 11:39 Found it , it was this line:
should be
ah, good that you found that one. The error checking within Dashticz is indeed pretty limited...
