Evohome Control From Dashboard
Posted: Saturday 13 November 2021 0:03
by Chopper
I have added my evohome system via API and am able to set the temperature when viewing the devices in the temperature tab, however, I am unable to set the temperature from the dashboard.
Is there any way to enable this? or a workaround
Ideally would also like to be able to set an 'override' timer so that I can for example set 'living room to 20 degrees for 2 hours' before returning to the normal schedule
I have tried googling and searching these forums and have not been able to find an answer.
Many thanks in advance.
Re: Evohome Control From Dashboard
Posted: Saturday 13 November 2021 22:43
by philchillbill
Chopper wrote:Hello,
Create a switch and make its on-action set the temperature and until-time via JSON using Python or Perl. Lua should work too but I don’t use it.
