Error: Zigate: Decode8000
Posted: Thursday 11 November 2021 22:07
by pfloryann
Today i updated plugin to 5.2.271 and domoticz to 2021.1 (build 13872) and i added Sonoff Motion sensor SNZB-03 but an error occurs.
it works well for a while but after a few hours it crashes the zigate, it no longer receives or sends commands . I don't know if the problem is caused by the sensor or the domoticz version.
Error: Zigate: Decode8000 - PacketType: 0092 TypeSqn: 01 sqn_app: 00 sqn_aps: bb Status: [0a]
I will attach the export file error from zigate.
Thank you in advance!
Re: Error: Zigate: Decode8000
Posted: Thursday 11 November 2021 22:12
by pipiche
did you try To Power Off and On the ZIGate ? Which ZiGate version is it ? which firmware ?
Posted: Thursday 11 November 2021 22:16
by pfloryann
I will try to power off.. Zigate Ttl , Firmware: 0320
Posted: Friday 12 November 2021 2:11
by pfloryann
Same error and same problem after 2-3hours...zigate not send commands.
Posted: Friday 12 November 2021 15:13
by pipiche
I suspect an Hardware issue with your ZiGate.
Are you having a USB-TTL module Blue or Red ?
You can mention that the ZiGate is starting to respond with 0x15 error and then continue with 0x0a
Posted: Friday 12 November 2021 17:29
by pfloryann
Blue version
Posted: Friday 12 November 2021 18:29
by pipiche
So if that is the blue, I know that there is some known issue with that one. So suggest that you contact the ZiGate vendor, or you purchase this one
https://zigate.fr/produit/module-usb-ttl-cp2102/
Posted: Saturday 13 November 2021 21:44
by pfloryann
Thank you!
I saw that i haven't errors in the last 24h
Posted: Wednesday 19 January 2022 7:07
by pfloryann
I changed usb-ttl with red version and i have the same error.
Firmware 321, zigate plugin 6 beta.
Posted: Tuesday 25 January 2022 18:58
by pipiche
Could you please share them ?
Posted: Monday 14 February 2022 7:58
by pfloryann
It's the same from the first post , now i m back to Firmware: 031e and no problem with this version from 1 month.
Posted: Monday 14 February 2022 8:17
by pipiche
If you are not putting any logs it is hard to say anything.
Could you also tell how many devices are connected.
Last I zouke not recommend using the latest plugin version with not the most recent firmware.
Posted: Tuesday 22 February 2022 18:47
by waltervl
@pipiche, I have similar errors regularly like below.
I do not know where they are coming from. I cannot relate it to a device. Can you? It does not seem to give issues I believe.
2022-02-22 18:03:11.851 Error: ZiGate: Decode8000 - PacketType: 0030 TypeSqn: 02 sqn_app: 00 sqn_aps: 22 Status: [ZigBee Error Code Unknown code : 80]
2022-02-22 18:06:23.656 Error: ZiGate: Decode8000 - PacketType: 0030 TypeSqn: 02 sqn_app: 00 sqn_aps: 4d Status: [ZigBee Error Code Unknown code : 80]
2022-02-22 18:06:30.282 Error: ZiGate: Decode8000 - PacketType: 0030 TypeSqn: 02 sqn_app: 00 sqn_aps: 51 Status: [ZigBee Error Code Unknown code : 80]
2022-02-22 18:06:30.499 Error: ZiGate: Decode8000 - PacketType: 0030 TypeSqn: 02 sqn_app: 00 sqn_aps: 52 Status: [ZigBee Error Code Unknown code : 80]
Plugin: 5.1.018
Firmware: 0321
For more info check the attached errors.json.
errors.json.txt
(17.84 KiB) Downloaded 24 times
export-raw.json.txt
(174.73 KiB) Downloaded 20 times
Posted: Tuesday 22 February 2022 19:32
by pipiche
For me this is a bad behaviour of the Zigate, i have the same on my production as well.
If you disable ReenforceConfigureReporting this would most-likely reduce those issue
Posted: Thursday 24 February 2022 17:16
by pipiche
I suggest that you are reporting this issue on the Zigate/Firmware side here https://github.com/fairecasoimeme/ZiGate/issues/394
as it is an existing know issue.
