Help me? Idea, add or sub text with push buttons
Thuis
Post by Thuis »
Hello, could some one help me with an idea i have?
Sorry i just do not know if it is possible, but like to ask if it is and how it could be done.
I want to read out a text device.
To init the text device i want to use a push button called "init".
When init is true, the text device goes to 20. (degrees)
Say i have a push button (temp+), when i push it, i want that text device to add one.
And say i have another push button (temp-), when i push it, i want the text device to sub one.
But i have no clue how to do this in domoticz lua or dzventz.
Im trying though:
-- Text for temp up
if push_Plus and init then
textdevice = initwaarde+1 elseif
push_Plus then
textdevice = textdevice+1
-- Text for temp down
if push_Min and init then
textdevice = initwaarde-1 elseif
push_Min then
textdevice = textdevice-1
Some help would be very nice, and thanks in advance.
Fun for everyone!
Thuis
Re: Help me? Idea, add or sub text with push buttons
Post by Thuis »
Thanks but no thanks, figured it out, using a counter instead of a textdevice.
Close topic, thank you.
Fun for everyone!
user4563
Domoticz version: 2026.4
Post by user4563 »
Can you please post the code to help others that may come across the same situation?
Aeotec Z-Stick Gen5+
ZWave-JS-UI / Mosquitto MQTT
Domoticz for Android
Well, for the same use case I would have used a Thermostat Setpoint device. There is a build in up/down button on it. So no need to use 2 extra buttons to set a temp higher or lower.
https://www.domoticz.com/wiki/Dummy_for ... t_Setpoint
