keros
Posts: 77 Joined: Saturday 27 July 2019 0:39
Post
by keros » Saturday 06 November 2021 18:46
Hello everyone,
I would to know if it is possibile to add explanation between parameters like for the
Evohome via web API :
Sans titre.png (108.52 KiB) Viewed 1979 times
I looked at differents plugin github repositories but none of them has description integrated between each parameters. They all have the
wiki code with only the label :
<params>
<param field="Address" label="IP Address" width="200px" required="true" default="127.0.0.1"/>
<param field="Port" label="Port" width="30px" required="true" default="9090"/>
<param field="Mode1" label="MAC Address" width="150px" required="false"/>
<param field="Mode2" label="Shutdown Command" width="100px">
<options>
<option label="Hibernate" value="Hibernate"/>
<option label="Suspend" value="Suspend"/>
<option label="Shutdown" value="Shutdown"/>
<option label="Ignore" value="Ignore" default="true" />
</options>
</param>
<param field="Mode3" label="Notifications" width="75px">
<options>
<option label="True" value="True"/>
<option label="False" value="False" default="true" />
</options>
</param>
<options>
<option label="False" value="Normal" default="true" />
</options>
</param>
</params>
</plugin>
Is it possibile to add the explanations ?
Dnpwwo
Posts: 820 Joined: Sunday 23 March 2014 9:00
Post
by Dnpwwo » Sunday 07 November 2021 8:01
Hi keros,
You can't in the current Domoticz stable but I liked this idea so I just pushed an update into the beta channel that allows it:
<plugin key="Timeout" name="Timeout Tester" author="Dnpwwo" version="2.2.7" externallink="https://www.google.com">
<description>
<h2>Timeout Tester</h2><br/>
Connect to URL and timeout with specified interval (milliseconds).
</description>
<params>
<param field="Address" label="IP Address" width="200px" required="true" default="localhost"/>
<param field="Mode1" label="Protocol" width="75px">
<options>
<option label="HTTPS" value="443"/>
<option label="HTTP" value="8080" default="true" />
</options>
</param>
<param field="Mode2" label="Timeout" width="50px" required="true" default="250">
<description>Values below 250 milliseconds will be ignored</description>
</param>
<param field="Mode6" label="Debug" width="150px">
<description><h2>Debugging</h2>Select the desired level of debug messaging</description>
<options>
<option label="None" value="0" default="true" />
<option label="Python Only" value="2"/>
<option label="Basic Debugging" value="62"/>
<option label="Basic+Messages" value="126"/>
<option label="Connections Only" value="16"/>
<option label="Connections+Python" value="18"/>
<option label="Connections+Queue" value="144"/>
<option label="All" value="-1"/>
</options>
</param>
</params>
</plugin>the description is shown above the parameter and can contain embedded HTML so it can be styled
keros
Post
by keros » Sunday 07 November 2021 9:14
Thank you very much Dnpwwo for your very quick action
I uptade to the lastest beta 13842 but I can not see the changes for the moment. That normal ? I have to wait for the next build ?
pipiche
Posts: 2048 Joined: Monday 02 April 2018 20:33
Post
by pipiche » Sunday 07 November 2021 9:20
I like that
Dnpwwo
Post
by Dnpwwo » Sunday 07 November 2021 20:42
Yes, it should be in the next beta build.
keros
Post
by keros » Sunday 07 November 2021 20:45
Wonderfull
Thanks a lot
keros
Post
by keros » Thursday 11 November 2021 10:06
The build changed (13872 now) but the description still not appears in the plugin page
Is it a problem on my side, or the modifications haven't been pushed yet ?
EDIT : I looked at my log and I have those errors for my test plugin
2021-11-11 10:12:21.352 Error: Test: (Timeout) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/Test/:/usr/lib/python37.zip:/usr/lib/python3.7:/usr/lib/python3.7/lib-dynload:/usr/local/lib/python3.7/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.7/dist-packages'.
2021-11-11 10:12:21.353 Error: Test: Module Import failed, exception: 'SyntaxError'
2021-11-11 10:12:21.353 Error: Test: Import detail: File: , Line: 1, offset: 1
2021-11-11 10:12:21.353 Error: Test: Error Line '<plugin key="Timeout" name="Timeout Tester" author="Dnpwwo" version="2.2.7" externallink="
https://www.google.com ">
2021-11-11 10:12:21.353 '
2021-11-11 10:12:21.353 Error: Test: No traceback available
The plugin.py is exactly the code you wrote above.
JanJaap
Posts: 248 Joined: Thursday 12 October 2017 20:46
Domoticz version: Dev
Post
by JanJaap » Saturday 13 November 2021 19:57
Hi Keros,
At first glance there seems to be an error already on the first line of your plugin. Sure that is all correct?
keros
Post
by keros » Saturday 13 November 2021 21:14
Thanks for your reply JanJapp
I tooked exactly the example given just above by Dnpwwo
I tried with the
wiki example code (which Dnpwwo has updated) and the description appears
<plugin key="Kodi" name="Kodi Players" author="dnpwwo" version="1.0.0" wikilink="http://www.domoticz.com/wiki/plugins/Kodi.html" externallink="https://kodi.tv/">
<description>
<h2>Kodi Media Player Plugin</h2><br/>
<h3>Features</h3>
<ul style="list-style-type:square">
<li>Comes with three selectable icon sets: Default, Black and Round</li>
<li>Display Domoticz notifications on Kodi screen if a Notifier name is specified and events configured for that notifier</li>
<li>Multiple Shutdown action options</li>
<li>When network connectivity is lost the Domoticz UI will optionally show the device(s) with a Red banner</li>
</ul>
<h3>Devices</h3>
<li>Status - Basic status indicator, On/Off. Also has icon for Kodi Remote popup</li>
<li>Volume - Icon mutes/unmutes, slider shows/sets volume</li>
<li>Source - Selector switch for content source: Video, Music, TV Shows, Live TV, Photos, Weather</li>
<li>Playing - Icon Pauses/Resumes, slider shows/sets percentage through media</li>
</ul>
</description>
<params>
<options>
</options>
</param>
<options>
</options>
</param>
<options>
</options>
</param>
</params>
</plugin>
madpatrick
Posts: 900 Joined: Monday 26 December 2016 12:17
Domoticz version: 2026.1
Post
by madpatrick » Wednesday 01 February 2023 20:06
Does anybody know if you can use these check boxes in a Python plugin ?
2023-02-01 20_04_49-(1) Domoticz - Post a reply.png (10.95 KiB) Viewed 1365 times
