Hi Folks,
I bought two new Z-Wave 700 sensors at Ali Express:
nas-pd07z, featuring PIR, Lux, Temperature and Humidity
nas-ds07z door sensor with Temperature and Humidity
They are not expensive and promise to have a very low battery usage.
In Domoticz there are no XML files and no listing in the manufacturer_specific.xml file under Config.
It seems that the Open Z-Wave platform is not updated for Z-Wave 700 devices.
Added this two lines in the Shenzen part:
<Product config="shenzen_neo/nas-ds07z.xml" id="0702" name="Door/Window Detector Z-Wave 700 V3 with temp and hum" type="0010"/>
<Product config="shenzen_neo/nas-pd07z.xml" id="0720" name="NAS-PD07Z Battery & DC Powered PIR Z-Wave 700 4 in 1" type="0010"/>
The nas-pd07z.xml was already created bij David J
Did the ds07z.xml myself.
Put the attached XML files (Zipped) in the Config/shenzen_neo map
Thanks,
Harry
Neo Coolcam Z-Wave 700 Door en PIR
HarryB
- Domoticz version: 2022-2
- new_700_ series_shenzen_neo_xml.zip
- (4.66 KiB) Downloaded 65 times
- heggink
- Domoticz version: 12451
Re: Neo Coolcam Z-Wave 700 Door en PIR
Are these already supported by zwavejs2mqtt?
P1 meter & solar panel
HarryB
Not sure, I am still on Open Z-wave
- heggink
Just interested. I have some neo coolcam plugs that gave me a ton of hassle using OZW but work flawlessly under zwavejs2mqtt...
