Combine 2 (or more) values for TTS to SONOS
Tjeerd13
Post by Tjeerd13 »
I'm trying to get TTS to sonos every time a switch change on/off
it's working ...the problem is i get a short delay between Switch name and the State on/off i would like to combine 2 messeage's
I get the value from a http request node:
http://192.168.10.17:8080/json.htm?type=devices&rid={{{topic}}}
From there i get the Name and status from the domoticz IDX with the below functions.
I have 2 funtion bloks
One with :
var name = { "payload": msg.payload.result[0].Name };
return  name;
And the other
var status = {"payload": msg.payload.result[0].Status };
return  status;
these 2 funtions are connected to TTS-Ultimate. And gives the example message Light Front ....delay... off or on
I tried to get one messeage Light front OFF
I can't get i working with:
I tested with :
var name = { payload: msg.payload.result[0].Name };
var status = {payload: msg.payload.result[0].Status };
return  [status,name];
I also tested it with the Join block. But unfortanliy i cant get it to work.
Anyone some sugestions how to get one payload with "Light Front on"
Pi3, Pi4, Pi4 for Testing, Dashticz, RFXtrx433, Nest: "Thermostat V2, V3, Hello". Honywell Lyric T6R, RFXCom, KaKu, HUE, P1, Open Zwave USB,
