Conbee USB stick connection issues
Posted: Sunday 17 October 2021 16:15
I have Domoticz 2021.1 running on a Pi Model 3b (running buster) and recently attached a Conbee 2 Zigbee USB-stick to it. However:
- Phoscon app tells me "firmware is disconnected" and
- Domoticz (on port 80) is telling me every 10th second: Error: ConbeeStick: (ConbeeStick) Startup failed. retrying....
Where am I and what did I do so far:
- I did follow these instructions to install the stick and connect to Domoticz: https://www.robbshop.nl/blog/conbee-usb ... nstalleren.
- I do see the Conbee listed under hardware in Domoticz.
- I can access the Phoscon app (on port 8080; version 2.13.01/6-10-2021) on my (the same) pi, but it complains about firmware not connected
- I already follow these instructions here: https://phoscon.de/en/support#conbee2-connection-issues .....however.......
...my ConBee-stick is *not* listed as a registered device under lsusb...the FAQ page only describes what to do next when using Docker or a virtual machine. I'm using neither one of them.
Dmesg is telling me lots of these:
[ 90.564016] usb 1-1.5: new full-speed USB device number 14 using dwc_otg
[ 90.708483] usb 1-1.5: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
[ 90.708539] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 90.708556] usb 1-1.5: Product: ConBee II
[ 90.708571] usb 1-1.5: Manufacturer: dresden elektronik ingenieurtechnik GmbH
[ 90.708586] usb 1-1.5: SerialNumber: DE2458103
[ 90.710048] cdc_acm 1-1.5:1.0: ttyACM1: USB ACM device
[ 94.078361] usb 1-1.5: USB disconnect, device number 14
[ 102.563858] usb 1-1.5: new full-speed USB device number 15 using dwc_otg
[ 102.718604] usb 1-1.5: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
[ 102.718632] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 102.718648] usb 1-1.5: Product: ConBee II
[ 102.718663] usb 1-1.5: Manufacturer: dresden elektronik ingenieurtechnik GmbH
[ 102.718678] usb 1-1.5: SerialNumber: DE2458103
[ 102.721278] cdc_acm 1-1.5:1.0: ttyACM1: USB ACM device
[ 106.369318] usb 1-1.5: USB disconnect, device number 15
First thing I note, I have a ttyACM0 device (the default) in /dev. The device ttyACM1 does not exist in /dev.
I have searched GitHub, the Discord channel and many places more, but...I'm lost on what to do.
ANY help would be much appreciated.
Thanks in advance and kind regards,
Michel.
Michel.
