Chint DTSU666-Modbus smart meter
Posted: Wednesday 13 October 2021 17:04
by elfabric
Hi.
Following the example of MFxMF I have written plugin for Chint DTSU666 smart meter:
https://github.com/elfabriceu/DTSU666-Modbus
- dtsu666-domoticz.jpg (204.99 KiB) Viewed 8230 times
log:
- dtsu666-domoticz2.png (58.91 KiB) Viewed 8230 times
Any feedback or suggestions are appreciated.
Best regards
Robert
Re: Chint DTSU666-Modbus smart meter
Posted: Monday 22 November 2021 23:37
by Ksala
Hi Robert
In your plugin on github i founded probably error.
there is
Volts_AB = self.rs485.read_float(0x2000, functioncode=4, numberOfRegisters=2)/10
should be
Volts_AB = self.rs485.read_float(0x2000, functioncode=3, numberOfRegisters=2)/10
for read modbus devices you shuld use function 3 against to 4 for all reads
After uploading your plugin from github domoticz was hanging. After making the correction I am writing about, everything started work perfectly.
Well done. Thanks a lot for greeat job.
Best Regards,
Krzysztof
Posted: Wednesday 08 December 2021 15:54
by elfabric
Hi Krzysztof,
The DTSU666 meter allows reading data using both functions 03 and 04. I haven't noticed any problems with the readings with function 04. Do you have a standard DTSU666 software version - not customized for Huawei, Hoymiles etc.? Just in case, I put on Github a plugin version that reads data using the 03 function. More tests would be nice.
Best regards
Robert
Posted: Tuesday 21 November 2023 18:55
by Wind06
I am new in Domoticz and need help, I am trying to make DTSU666-Modbus working, I followed all instructions I guess.
but I am unable to make it work, I do have errors in logs. I don't know if the problem is coming from my USB/RS485 which is not
working or is it a configuration issue.
The USB device is a Waveshare Industrial USB to RS485 Converter with Original FT232RL Automatic Transceiving Embedded Protection Circuits Such as Fuse ESD Protection and TVS Diode
Any help will be very much appreciated
When stating the plugin I get the following errors:
Call to function 'onHeartbeat' failed, exception details:
.Log('Voltage L1-L2: {0:.3f} V'.format(Volts_AB))
UnboundLocalError: local variable 'Volts_AB' referenced before assignment
Posted: Tuesday 27 August 2024 21:10
by Nusiek
Witam wszystkich
Posiadam falownik Huawei SUN2000, licznik DTSU666 oraz MBtranslator do odczytu po TCP IP danych z falownika. Jak uruchomić taki zestaw aby był możliwy odczyt w Domoticzu?
Pozdrawiam
