openURL timeout  [Solved]
Number8
Domoticz version: 2022.1
openURL timeout
Post by Number8 »
Hello to all
I have a very strange timeout issue for a long time that I really don't how to sort out.
After 15 sec this url call triggers a timeout reported in the log file
local wunderURL = "https://api.weather.com/v3/wx/forecast/daily/5day?geocode=47.097,1.966&language=fr-FR&format=json&units=m&apiKey=xxx"
dz.openURL({
   url = wunderURL,
   callback = "wundergroundResponseForecast1"
log file excerpt
2021-10-10 20:25:17.214 Error: Error opening url: https://api.weather.com/v3/wx/forecast/daily/5day?geocode=47.097,1.966&language=fr-FR&format=json&units=m&apiKey=xxx
2021-10-10 20:25:17.291 Error: dzVents: Error: (3.0.14) meteo script: HTTP/1.1 response: 28 ==>> Timeout was reached
If I simply copy/past without waiting the url displayed in the log file in a browser I get an immediate answer
So what could make the API not responding?
Running 2020.2 build 12485 on Debian buster
Thank you
Debian buster on NUC and three RPi with buster.
Re: openURL timeout
Do you do that test on the same system?
Is there a limit of calls on wunderground?
Number8
Re: openURL timeout
Post by Number8 »
Thanks waltervl. It turns out that a curl on the same machine (NUC Intel i5) takes roughly 10 sec that I guess is the timeout limit. On the same network doing the same request in a PC browser triggers the response almost immediately. Doing the same request on an RPi gear takes 15 sec as well. Size of the response is 6Ko. Network is 1Gb wired.
2 questions then: why such a timing difference? and is there a way to increase timeout limit, at least on a per http call basis?
Lokonli
Re: openURL timeout
Post by Lokonli »
Are you maybe using IPv6? That might give issues with curl.
Verstuurd vanaf mijn AC2003 met Tapatalk
Number8
Re: openURL timeout
Post by Number8 »
No IPv4
EddyG
Re: openURL timeout
Post by EddyG »
I have it sometimes too (and for years), sometimes a few times per day and sometimes only a few times per week.
I just ignore it. It might be that at that time the RPi or weather.com are busy. Don't call more often then every 15 minutes.
It does not really matter if a few calls are missed per day, weather does not change that fast. ;)
Number8
Re: openURL timeout
Post by Number8 »
I was not worried until it did not work anymore. So I guess it is a different issue, isn'it? I call it once every hour maximum :(
Re: openURL timeout
A little google brought me here https://serverfault.com/questions/85864 ... n-centos-7
Could give it a try.
Number8
Re: openURL timeout
Post by Number8 »
Could it be a DNS lookup issue with curl?
Re: openURL timeout  [Solved]
Try the the test options as mentioned here https://aarvik.dk/disable-ipv6/
Number8
Re: openURL timeout
Post by Number8 »
I did it right away. I get quick response time in both cases
Number8
Re: openURL timeout
Post by Number8 »
Anyhow, as advised in https://aarvik.dk/disable-ipv6/ the following line as been appended to /etc/resolv.conf-file
options single-request-reopen
The response time is now 5 sec, which is still long compared to a browser, but below the 10 sec timeout.
Thank to all you for the help. Was not an obvious problem.
