Find distance between 2 objects (Lat/Lon required)
Posted: Friday 08 October 2021 17:07
Hello All,
While reading some posts on this forum, I came across viewtopic.php?f=65&t=37123&p=280417&hil ... ta#p280417 and saw that the Toyota API is obviously capable to indicate
On a rainy afternoon, I decided to implement it for my Volvo Car and the distance to my Home, but it can also be used for the distance between two persons or between a person and the home address. But the final use case is up to your imagination
Requirements:
See: https://owntracks.org/ or https://f-droid.org/en/packages/org.nexttracks.android/
Ad 2. This application uses the API from http://project-osrm.org/ (OSRM: Open Source Routing Machine) with uses the data from OpenStreetMap).
For detailed information of the API, see the documentation on the OSRM website.
I created the following Node Red flow:
First, at the top left, we will see an "Inject" node. Nothing special, but it will trigger a "HTTP Request" node in order to get the settings from Domoticz as put in the Latitude and Longitude fields. Normally this is a "one time" setting and it will hopefully not change very often
. If it changes, you have another problem and we should make something to detect earthquakes. You can also put that value in the "Inject" node.
It requests the Lat/Lon of your "Home" only once, as the flow is started.
As I own a Volvo Car and use the Volvo On Call application (See: viewtopic.php?f=38&t=26549&hilit=Volvo),
I will receive the Lat/Lon co-ordinates from VoC only if the car has come to a standstill. So it is probably better to use the Smartphone.
But for the first release it is fine.
The two different sets of co-ordinates (Home and Car) are joined and parsed in the next "Change" node.
The next step is to prepare the URL to query the OSRM API.
The contents of the "Function" node is as follows:
This "Function" node configures the different possible settings. See the previous mentioned documentation.
I limited the number of digits of Lat and Lon after the decimal point to 6.
In order to avoid flooding of the OSRM API, I did use a "Filter" node (previous called a "RBE' node.
You will receive the "Duration" in "Seconds" and the "Distance" in "Meters". In order to avoid a huge number of seconds, if you are far away, I converted it to milliseconds (with the "Change" node and the JSONATA expression and the "Moment" node.
The next question is, what type of Domoticz Sensor to use?
Domoticz has a Sensor of the type "Distance", but you can only set that to cm. Not very useful
The next possibility is the "Custom" sensor. However that sensor can only display 1 value.
As I wanted 2 values (Distance and Duration) and decided to use the "Text" sensor (Icon has been changed)
The result is as follows (for a car at home):
Please find the complete flow below:
I'm open for suggestions, ideas, comments etc.
Have Fun and Best Regards
Of course it is questionable, what the use case is for such a function, but you might think of an action to carry out (start the coffee machine: D ), in case you are approaching your home (e.g. the distance is less than .... or the duration to reach your home is less than ....)Distance to home - Shows the distance between the car and home
Requirements:
- Object has to present the Lat/Lon co-ordinates
- Domoticz connected to the Internet
- MQTT broker (Mosquitto installed
- Node Red installed
var url = "http://router.project-osrm.org";
var service = "route";
var version = "v1";
var profile = "driving";
var options = "?overview=false&generate_hints=false&skip_waypoints=true"
msg.url = url + "/" + service + "/" + version + "/" + profile + "/" + msg.payload.home_lon + "," + msg.payload.home_lat + ";" + msg.payload.car_lon.toFixed(6).toString() + "," + msg.payload.car_lat.toFixed(6).toString() + options;
return msg;I limited the number of digits of Lat and Lon after the decimal point to 6.
[{"id":"cb78f72ce183cc3f","type":"tab","label":"Car-Home Distance","disabled":false,"info":""},{"id":"714e4cf506f868f1","type":"http request","z":"cb78f72ce183cc3f","name":"HTTP Domoticz","method":"GET","ret":"obj","paytoqs":"ignore","url":"http://192.168.10.50:8080/json.htm?type=settings","tls":"","persist":false,"proxy":"","authType":"","credentials":{},"x":400,"y":80,"wires":[["8e57561dad7fa6af"]]},{"id":"5c0992b908348937","type":"inject","z":"cb78f72ce183cc3f","name":"Request Home GPS","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"home_GPS","payloadType":"date","x":160,"y":80,"wires":[["714e4cf506f868f1"]]},{"id":"6a9ba37b7eec1ef5","type":"mqtt in","z":"cb78f72ce183cc3f","name":"MQTT-Owntracks Volvo","topic":"owntracks/volvo/ABC123","qos":"2","datatype":"json","broker":"2d06e6e96ce54335","nl":false,"rap":false,"x":380,"y":160,"wires":[["8e57561dad7fa6af"]]},{"id":"eb27ba6c0c8636e9","type":"http request","z":"cb78f72ce183cc3f","name":"","method":"GET","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":false,"proxy":"","authType":"","x":570,"y":280,"wires":[["49b658305e195907"]]},{"id":"b8729301cea6773c","type":"function","z":"cb78f72ce183cc3f","name":"Create URL OSRM","func":"var url = \"http://router.project-osrm.org\";\nvar service = \"route\";\nvar version = \"v1\";\nvar profile = \"driving\";\nvar options = \"?overview=false&generate_hints=false&skip_waypoints=true\"\n\nmsg.url = url + \"/\" + service + \"/\" + version + \"/\" + profile + \"/\" + msg.payload.home_lon + \",\" + msg.payload.home_lat + \";\" + msg.payload.car_lon.toFixed(6).toString() + \",\" + msg.payload.car_lat.toFixed(6).toString() + options;\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":170,"y":280,"wires":[["bd723b5404883010"]]},{"id":"8e57561dad7fa6af","type":"join","z":"cb78f72ce183cc3f","name":"Join GPS","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":600,"y":120,"wires":[["9b499945b6a77dd2"]]},{"id":"9b499945b6a77dd2","type":"change","z":"cb78f72ce183cc3f","name":"","rules":[{"t":"move","p":"payload.home_GPS.Location.Latitude","pt":"msg","to":"payload.home_lat","tot":"msg"},{"t":"move","p":"payload.home_GPS.Location.Longitude","pt":"msg","to":"payload.home_lon","tot":"msg"},{"t":"move","p":"payload[\"owntracks/volvo/ABC123\"].lat","pt":"msg","to":"payload.car_lat","tot":"msg"},{"t":"move","p":"payload[\"owntracks/volvo/ABC123\"].lon","pt":"msg","to":"payload.car_lon","tot":"msg"},{"t":"delete","p":"payload.home_GPS","pt":"msg"},{"t":"delete","p":"payload[\"owntracks/volvo/ABC123\"]","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":800,"y":120,"wires":[["b8729301cea6773c"]]},{"id":"bd723b5404883010","type":"rbe","z":"cb78f72ce183cc3f","name":"Filter","func":"rbe","gap":"","start":"","inout":"out","septopics":false,"property":"payload","topi":"topic","x":390,"y":280,"wires":[["eb27ba6c0c8636e9"]]},{"id":"d68a160b6fa6988b","type":"inject","z":"cb78f72ce183cc3f","name":"Reset","props":[{"p":"reset","v":"true","vt":"bool"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":210,"y":340,"wires":[["bd723b5404883010"]]},{"id":"001542253fa72c7b","type":"function","z":"cb78f72ce183cc3f","name":"Prepare Domoticz","func":"msg.payload = {\n \"command\": \"udevice\",\n \"idx\": 11,\n \"nvalue\": 0,\n \"svalue\": \"Distance: \" + (msg.payload.routes[0].distance / 1000).toFixed(4).toString() + \" km \\n Duration: \" + (msg.payload.routes[0].duration).toString()\n };\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":750,"y":360,"wires":[["932177559ea7358f"]]},{"id":"932177559ea7358f","type":"mqtt out","z":"cb78f72ce183cc3f","name":"To Domoticz","topic":"domoticz/in","qos":"0","retain":"false","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"f9f13036.e28b58","x":970,"y":360,"wires":[]},{"id":"88187caba49c039b","type":"moment","z":"cb78f72ce183cc3f","name":"Format Time","topic":"","input":"payload.routes[0].duration","inputType":"msg","inTz":"ETC/GMT","adjAmount":0,"adjType":"days","adjDir":"add","format":"HH:mm:ss","locale":"en_US","output":"payload.routes[0].duration","outputType":"msg","outTz":"ETC/GMT","x":970,"y":280,"wires":[["001542253fa72c7b"]]},{"id":"49b658305e195907","type":"change","z":"cb78f72ce183cc3f","name":"To millisecs","rules":[{"t":"set","p":"payload.routes[0].duration","pt":"msg","to":"msg.payload.routes[0].duration*1000","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":770,"y":280,"wires":[["88187caba49c039b"]]},{"id":"2d06e6e96ce54335","type":"mqtt-broker","name":"Jonas_MQTT_Server","broker":"192.168.10.24","port":"1883","clientid":"","usetls":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"sessionExpiry":""},{"id":"f9f13036.e28b58","type":"mqtt-broker","name":"localhost","broker":"127.0.0.1","port":"1883","clientid":"","usetls":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthRetain":"false","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"sessionExpiry":""}]Have Fun and Best Regards
