LAN interface for RFXtrx433XL available
b_weijenberg
Post by b_weijenberg »
The RFXtrxLAN module for the RFXtrx433XL or RFXtrx868XL is available now, see http://blog.rfxcom.com/
Note: the RFXtrx433 and RFXtrx433E do not have the right connection points so that the 4 pins header cannot be used and use of these transceivers needs a precise soldering technique!
RFX-433, RFX-433EMC, RFX-868
nigels0
Domoticz version: 3.8153
Re: LAN interface for RFXtrx433XL available
Post by nigels0 »
Has this been tested with Domoticz? I used the following, which worked well until about a year ago - then it wouldn’t initialise.
viewtopic.php?f=6&t=30642&p=257118#p257118
Here is the original mode de emploi
viewtopic.php?f=44&t=18453&p=149775#p149775
b_weijenberg
b_weijenberg
Now also available with a WiFi controller.
The LAN and WiFi RFXtrxLAN can be used at the same time by multiple Home Automation applications.
