Update Wiki with clear instructions on missing Add button
Posted: Sunday 03 October 2021 17:23
I posted an earlier comment about the Add button missing in the Setup/Hardware page and was given the correct answer (clear the browser cache or use a private browser window). But the wiki should provide this information in the page dedicated to adding hardware.
I am not in the Users group so I cannot modify the wiki page. But if I could, I would open the Hardware_Setup page (https://www.domoticz.com/wiki/Hardware_Setup) and change this:
to be something like this:===Setting up a LAN hardware===
First make sure you know the IP address and port of the device.<br>
[[File:LAN Hardware.png]]<br>
By pressing the ADD button, the hardware is added to the system and will automatically start.
==Update Hardware Gateway==
When hardware is added the overview of all defined hardware will be shown.
(The above formatting is just a guess, sorry if it isn't quite right.)===Setting up a LAN hardware===
===If the Add button is missing===
If your browser does not show an Add button, you need to clear the browser's cache and reload the page.
Instructions for clearing the cache vary, based on the browser; check your browser's Help feature.
Alternatively, you can view the Domoticz Setup/Hardware page using a private window in your browser. Check your browser's Help feature for instructions on opening a private browser window.
