aurora theme in windows domoticz instalation stop working last update
Posted: Sunday 03 October 2021 14:20
by pmalvino
Hello.
Need some help, after updating domoticz windows instalation from 2020_2.12917 to 2021_1.13680 the aurora theme doesnt work
Captura de ecrã 2021-10-03 131736.png (46.54 KiB) Viewed 5701 times
do you have any idea what is hapening?
Thank you
Re: aurora theme in windows domoticz instalation stop working last update
Posted: Sunday 03 October 2021 14:26
by erem
Posted: Sunday 03 October 2021 14:52
by pmalvino
try it with some computers and the same.
not a cache problem.
Posted: Sunday 03 October 2021 15:16
by erem
then maybe it's the same problem as with the Machinon theme, and the author needs to take action.
viewtopic.php?f=6&t=37117
Posted: Sunday 03 October 2021 15:39
by pmalvino
thank you.
it seems to be the same problem, i lost the theme button in settings menu and try the machinon theme and the same problem.
Posted: Tuesday 05 October 2021 8:54
by galadril
I already created a Issue on github >
https://github.com/flatsiedatsie/domoti ... me/pull/76
And this PR should fix the issue >
Posted: Sunday 31 October 2021 10:34
by Bospieper
I'm on the Auroratheme and experienced the same problem as mentioned in a earlyer topic. I solved it by changing acttheme to styles/aurora. But I'm still facing the problem of not being able to save settings. Domoticz give the red error message that it is not possible to save the changes and on top of that domoticz GUI crashes.
Are there more users with the same problem and maybe a solution?
I use Chrome as webbrowser and cleared both caches several times.
Posted: Monday 01 November 2021 7:10
by kiddigital
Try switching to the Default theme and see if Save settings works there.
In Chrome you van open the Developer tools (F12) and see what is going on. Might be useful to post any errors you see there.
Posted: Monday 01 November 2021 13:30
by Bospieper
The problem is that none of the setting changes are saved. So it is not possible to change from theme.
In regards to the F12 state in Chrome. Wich menu item you want data from?
Posted: Monday 01 November 2021 13:41
by Bospieper
Posted: Monday 01 November 2021 15:29
by kiddigital
Check the 'Network' tab and then look for the line with the 'json.htm?type=command&param=storesettings' (make sure you have 'preserve log' and 'disable cache' checked).
For this call, the 'Headers' and 'Response' data is probably the most interesting part.
Also, in the printscreen there is an error shown with the POST of the settings. Would be interesting to see what additional info it reveals.
Does the Domoticz back-end crash when saving settings? Do you need to restart Domoticz first before the UI works again?
Posted: Monday 01 November 2021 20:46
by Bospieper
Hi Kiddigital,
Here's my log from the moment I hit the button "Save".
The Domoticz GUI crashes and with sudo service domoticz stop and start the system is working again, no changes are saved.
Posted: Tuesday 02 November 2021 6:57
by kiddigital
That is indeed the line. Please select it (the red one) and show the details, especially the Headers and Response (also Request data).
Posted: Tuesday 02 November 2021 15:51
by Bospieper
Headers
URL aanvragen: http://192.168.178.178:8080/json.htm?ty ... resettings
Verwijzersbeleid: strict-origin-when-cross-origin
Accept: application/json, text/plain, */*
Accept-Encoding: gzip, deflate
Accept-Language: nl-NL,nl;q=0.9,en-US;q=0.8,en;q=0.7
Cache-Control: no-cache
Connection: keep-alive
Content-Length: 12455
Content-Type: multipart/form-data; boundary=----WebKitFormBoundaryPeMJuRw5HwtPBzvC
Cookie: _ga=GA1.1.632086575.1634980758; DMZSID=bb705c8d30a509abc409814ac834d165_ZDJhODcxNzQtMjNkYy00YWYwLWJkMTQtMjFkNjIwZWJhNzMy.1635865049
Host: 192.168.178.178:8080
Origin: http://192.168.178.178:8080
Pragma: no-cache
Referer: http://192.168.178.178:8080/
User-Agent: Mozilla/5.0 (Linux; Android 6.0; Nexus 5 Build/MRA58N) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/95.0.4638.54 Mobile Safari/537.36
type: command
param: storesettings
Language: nl
Themes: default
DashboardType: 0
AllowWidgetOrdering: on
MobileType: 1
Title: Domoticz
Latitude: 53.173849
Longitude: 5.818679
WebUserName: XXXX
WebPassword:
AuthenticationMethod: 1
GuestUser: 0
SecPassword: d41d8cd98f00b204e9800998xxxxxxx
SecOnDelay: 0
ProtectionPassword: d41d8cd98f00b204e98009xxxxxxx
WebLocalNetworks: 127.0.0.*;192.168.178.*
RemoteSharedPort: 6144
checkforupdates: on
ReleaseChannel: 1
enableautobackup: on
WebRemoteProxyIPs:
AcceptNewHardware: on
HideDisabledHardwareSensors: on
MyDomoticzUserId:
MyDomoticzPassword:
LightHistoryDays: 2
ShortLogDays: 2
ProwlAPI:
IFTTTAPI:
PushbulletAPI:
PushsaferAPI:
PushsaferImage:
PushoverEnabled: on
PushoverUser: uqjyxc4kp9krx6nwvkppcsxxxxxxxx
PushoverAPI: aiu58eiryas7fzkf8h9i9eexxxxxxxx
PushALotAPI:
ClickatellAPI:
ClickatellTo:
ClickatellFrom:
TelegramAPI:
TelegramChat:
HTTPField1:
HTTPField2:
HTTPField3:
HTTPField4:
HTTPTo:
HTTPURL: https://www.somegateway.com/pushurl.php ... e=#MESSAGE
HTTPPostData:
HTTPPostContentType: application/json
HTTPPostHeaders:
KodiIPAddress: 224.0.0.1
KodiPort: 9777
KodiTimeToLive: 5
LmsPlayerMac:
LmsDuration: 5
NotificationSensorInterval: 600
NotificationSwitchInterval: 0
EmailEnabled: on
EmailFrom:
EmailTo:
EmailServer:
EmailPort: 25
EmailUsername:
EmailPassword:
UseEmailInNotifications: on
TempUnit: 0
DegreeDaysBaseTemperature: 18.0
WindUnit: 4
WeightUnit: 0
EnergyDivider: 1000
CostEnergy: 0.2149
CostEnergyT2: 0.2149
MaxElectricPower: 6000
CostEnergyR1: 0.0800
CostEnergyR2: 0.0800
GasDivider: 100
CostGas: 0.6218
WaterDivider: 100
CostWater: 1.6473
ElectricVoltage: 230
CM113DisplayType: 1
SmartMeterType: 0
FloorplanPopupDelay: 750
FloorplanAnimateZoom: on
FloorplanShowSensorValues: on
FloorplanShowSwitchValues: on
FloorplanShowSceneNames: on
FloorplanRoomColour: Blue
FloorplanActiveOpacity: 25
FloorplanInactiveOpacity: 5
RandomSpread: 15
SensorTimeout: 60
BatterLowLevel: 0
DoorbellCommand: 0
RaspCamParams: -w 800 -h 600 -t 1
UVCParams: -S80 -B128 -C128 -G80 -x800 -y600 -q100
EnableEventScriptSystem: on
LogEventScriptTrigger: on
EventSystemLogFullURL: on
DisableDzVentsSystem: on
DzVentsLogLevel: 1
themevar11: dashboard_move_sun
themevar12: navigation_main_sidebar
themevar13: navigation_settings_sidemenu
themevar14: center_popups
themevar16: mobile_phoney
themevar21: dashboard_show_last_update
themevar28: time_ago
themevar26: dashboard_merge_items_with_same_name
themevar29: dashboard_hide_section_titles
backgroundimageurl:
EnableTabLights: on
EnableTabScenes: on
EnableTabTemp: on
EnableTabWeather: on
EnableTabUtility: on
Posted: Tuesday 02 November 2021 15:55
by Bospieper
Response
Posted: Tuesday 02 November 2021 15:56
by Bospieper
Timing
Posted: Friday 05 November 2021 20:19
by Bospieper
Hi Kiddigital,
Did you find anything in the data I send you? Perhaps possible solution?
Grz. Piet
Posted: Thursday 13 January 2022 12:22
by Creo2005
After last dev update - Domoticz not working :( return with backup.
Posted: Thursday 13 January 2022 13:40
by FireWizard
Please do not post the same issue at multiple topics.
See: viewtopic.php?f=47&t=37801
