dzvents .json to device
Posted: Saturday 02 October 2021 17:45
Hello, im trying to make a script that reads a json file from http (example at below) and send those values to the appropriate devices in this case a pm2.5, pm10, humidity and a temperature sensor. i tried using this script https://domoticz.com/forum/viewtopic.php?t=26021script that i found in another thread but i can't get it to work. i have been searching for an answer for hours now but i can't find anything im a total newbie at coding but this didn't sound too difficult to do but apparently i was wrong
Domoticz log:
This is the code i got so far:
JSON im trying to read
Domoticz log:
2021-10-02 17:33:00.509 Status: dzVents: Info: Air quality: ------ Start internal script: airrohr:, trigger: "every 1 minutes"
2021-10-02 17:33:00.536 Status: dzVents: Debug: Air quality: Processing device-adapter for airrohr PM10: Custom sensor device adapter
2021-10-02 17:33:00.537 Status: dzVents: Debug: Air quality: Processing device-adapter for airrohr PM2.5: Custom sensor device adapter
2021-10-02 17:33:00.537 Status: dzVents: Debug: Air quality: OpenURL: url = http://192.168.1.152/data.json
2021-10-02 17:33:00.537 Status: dzVents: Debug: Air quality: OpenURL: method = GET
2021-10-02 17:33:00.537 Status: dzVents: Debug: Air quality: OpenURL: post data = nil
2021-10-02 17:33:00.537 Status: dzVents: Debug: Air quality: OpenURL: headers = nil
2021-10-02 17:33:00.537 Status: dzVents: Debug: Air quality: OpenURL: callback = Air quality
2021-10-02 17:33:00.537 Status: dzVents: Info: Air quality: ------ Finished airrohr
2021-10-02 17:33:00.537 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2021-10-02 17:33:00.666 Status: dzVents: Info: Handling httpResponse-events for: "Air quality"
2021-10-02 17:33:00.667 Status: dzVents: Info: Air quality: ------ Start internal script: airrohr: HTTPResponse: "Air quality"
2021-10-02 17:33:00.680 Status: dzVents: Debug: Air quality: Processing device-adapter for airrohr PM10: Custom sensor device adapter
2021-10-02 17:33:00.681 Status: dzVents: Debug: Air quality: Processing device-adapter for airrohr PM2.5: Custom sensor device adapter
2021-10-02 17:33:00.681 Status: dzVents: Info: Air quality: ------ Finished airrohr
2021-10-02 17:33:00.681 Error: dzVents: Error: (3.0.2) Air quality: An error occurred when calling event handler airrohr
2021-10-02 17:33:00.681 Error: dzVents: Error: (3.0.2) Air quality: ...i/domoticz/scripts/dzVents/generated_scripts/airrohr.lua:41: attempt to index a nil value (field '?')
local scriptVar = 'Air quality'
return
on =
timer =
'every 1 minutes', -- adjust to your needs
devices =
-- 'JSONTrigger', -- only used for test / development/ Can be ignored
httpResponses =
scriptVar,
logging =
level = domoticz.LOG_DEBUG, -- set to domoticz.LOG_ERROR when all OK
marker = scriptVar,
execute = function(dz, item)
local pm10 = dz.devices('airrohr PM10') -- define as air quality
local pm25 = dz.devices('airrohr PM2.5') -- define as air quality
if item.isTimer or item.isDevice then
dz.openURL({
url = 'http://192.168.1.152/data.json',
callback = scriptVar,
return
if item.isHTTPResponse and item.isJSON then
-- dz.utils.dumpTable(item.json) -- Only for debug purposes
local latestAirQuality = item.json[1].sensordatavalues
pm10.updateAirQuality(latestAirQuality[0].value)
pm25.updateAirQuality(latestAirQuality[1].value)
domoticz.log('There was a problem handling the request', domoticz.LOG_ERROR)
domoticz.log(item, domoticz.LOG_ERROR)
software_version "NRZ-2020-133"
age "30"
sensordatavalues
0
value_type "SDS_P1"
value "9.95"
1
value_type "SDS_P2"
value "3.60"
2
value_type "BME280_temperature"
value "23.11"
3
value_type "BME280_pressure"
value "100378.88"
4
value_type "BME280_humidity"
value "56.71"
5
value_type "samples"
value "5058621"
6
value_type "min_micro"
value "28"
7
value_type "max_micro"
value "20037"
8
value_type "interval"
value "145000"
9
value_type "signal"
value "-42"
