thermostat
Posted: Saturday 02 October 2021 6:12
by Cdzn
Hello there. I have thermostat and would like to heat and cool in time. I wrote these script but can`t change setpoint from it.
local timer1 = 'every minute' --'at 06:00'
timer = { timer1}
logging = { level = domoticz.LOG_DEBUG },
execute = function(domoticz,item,devices)
if (item.isTimer) then domoticz.devices(3).SetPoint= 26
Setpoint just don`t setting at thermostat
Re: thermostat [Solved]
Posted: Saturday 02 October 2021 8:29
by besix
Change
to
if (item.isTimer) then domoticz.devices(3).updateSetPoint(26)
Re: thermostat
Posted: Saturday 02 October 2021 9:08
by Cdzn
besix wrote: Saturday 02 October 2021 8:29
Change
to
What I just didn’t do. Thanks. Why setpoint does`t work?
Re: thermostat
Posted: Saturday 02 October 2021 9:46
by EddyG
Re: thermostat
Posted: Saturday 02 October 2021 9:47
by besix
timer = {'every minute'}, -- causes the script to be called every minute
execute = function(domoticz,item)
domoticz.devices('SetPoint').updateSetPoint(26)
Rename SetPoint to your thermostat and check
Re: thermostat
Posted: Saturday 02 October 2021 12:33
by Cdzn
besix wrote: Saturday 02 October 2021 9:47
Your 1st answer working. Thank You! every minure just for testing.
Re: thermostat
Posted: Saturday 02 October 2021 14:49
by Cdzn
One more question. How to make this work with 2 different timers
- Spoiler: show
local Timer1 = 'at 19:43'
local Timer2 = 'at 19:44'
timer = {Timer1, Timer2}
return
if (item.isTimer) then domoticz.devices(3).updateSetPoint(24.5)
return
Re: thermostat
Posted: Saturday 02 October 2021 17:47
by besix
I think it will help
return
on =
{timer =
{'at 8:00',
'every 3 minutes between 9:30 and 23:00',
'at 23:01' }
execute = function(dz, item)
if item.isTimer then
if dz.time.matchesRule('at 8:00') then
dz.devices('SetPoint').updateSetPoint(24)
if dz.time.matchesRule('every 3 minutes between 9:30 and 23:00') then
dz.devices('SetPoint').updateSetPoint(23)
if dz.time.matchesRule('at 23:01') then
dz.devices('SetPoint').updateSetPoint(21)
Re: thermostat
Posted: Saturday 02 October 2021 17:57
by Cdzn
besix wrote: Saturday 02 October 2021 17:47
return
on =
{timer =
{'at 8:00',
'at 23:01' }
Thank You!!!
Re: thermostat
Posted: Monday 04 October 2021 20:50
by rrozema
Many thermostats have a 'mode' setting, switching between 'economy' and 'normal' modes. Both modes have their own setpoint, so you need to set the both temperatures only once, and you only switch the mode control from economy to normal and vice versa. This allows you to still adjust the 'normal' setpoint manually without having to re-code your script.
If your thermostat doesn't have such an economy mode, have a look at SVT, the
Smart Virtual Thermostat plugin. If you can switch your heating on and off from domoticz using for example a simple esp relay, use this plugin to replace your normal thermostat and most likely you'll get better comfort plus on top of that use less energy for heating your house.
Re: thermostat
Posted: Wednesday 13 October 2021 11:45
by Cdzn
rrozema wrote: Monday 04 October 2021 20:50
The problem is i using handmade thermostate with Nextion display and internal ESPeasy thermostat, not in domoticz, to have a possibility to change setpoint from Domoticz or from touchscreen.
NExt step i want to make script like this, which remember last setpoint, turn thermostate ON, after 30 minutes return setpoint to last value.
devices = {
'Принудительный нагрев',
logging = {
level = domoticz.LOG_INFO,
marker = 'template',
execute = function(domoticz, switch)
--local Lastsp = domoticz.devices(3).updateSetPoint(25)
if (switch.state == 'On')
then domoticz.devices(3).updateSetPoint(27)
switch.switchOff().afterMin(30)
elseif (switch.state == 'Off')
then domoticz.devices(3).updateSetPoint(24)
Re: thermostat
Posted: Wednesday 13 October 2021 16:13
by rrozema
If you are in control om the software inside the thermostat, why don't you rewrite it to be a device to show and enter a setpoint only. The setpoint set is sent into a setpoint device in Domoticz Then have your Domoticz do the actual work of regulating the heat source. For example by using svt.
Re: thermostat
Posted: Thursday 14 October 2021 11:45
by Cdzn
rrozema wrote: Wednesday 13 October 2021 16:13
I have no idead how to make it works
Re: thermostat
Posted: Thursday 14 October 2021 22:04
by rrozema
Cdzn wrote: Thursday 14 October 2021 11:45
I assumed you had written the software in the thermostat yourself.
