Dahua VT02202F doorbell button detect ?
Posted: Friday 01 October 2021 15:45
by pascalspits
How can I get my Domoticz to detect when somebody is at my door (pushed the Dahua doorbell button) ?
I would like to have a Domoticz device to be on/off when the button is pressed, so I can make Domoticz do different things as a reaction to somebody pressing the doorbell button ...
The Dahua doorbell unit is POE LAN connected, so it should be possible to detect this button-press ?
https://www.dahuasecurity.com/asset/upl ... 191228.pdf
Thanks in advance !
Pascal
Re: Dahua VT02202F doorbell button detect ?
Posted: Wednesday 06 October 2021 12:10
by pascalspits
here is a guy setting it up in Home Assistant ...
https://youtu.be/1U6SQDU6f24
... how about in Domoticz ?
Do any of the smart guys in here have any idea how to do it ?
I don't need MQTT necessarily, I only need to update a virtual switch when the button is pushed ... that's all ...
Posted: Wednesday 06 October 2021 20:02
by hoeby
Check this on github:
https://github.com/riogrande75/Dahua
Not a finished optioneel for domoticz.
But the .php scripts give a good start for what you are looking for
Posted: Saturday 09 October 2021 8:25
by pascalspits
I'm not a coder ...
anybody know how to modify one of these scripts to detect a button-press on the doorbell and update a domoticz device according to it ?
Posted: Saturday 09 October 2021 9:03
by hoeby
Does the doorbell have a chime?
Some camera doorbell have a chime, which they control by 433mhz signal. If yours also have that, for scanning 433mhz there are multi tools online.
Sorry, modifying the code on github is out of my range. But i can help you with a code/manual for sniffing 433mhz and switch a dummy device in domoticz.
Posted: Saturday 09 October 2021 9:10
by pascalspits
it doesn't have a chime ... that's the problem ...
the chime is integrated in the indoor screen device ...
this indoor device detects (over LAN) that the button is pressed (so does Home Assistant, through API) ...
so, I need to sniff out (API ?) when the button is pressed to update a dummy device in Domoticz
makes sense ?
hoeby wrote: Saturday 09 October 2021 9:03
Posted: Thursday 14 October 2021 11:15
by pascalspits
nobody ?
Posted: Friday 15 October 2021 8:23
by lost
pascalspits wrote: Thursday 14 October 2021 11:15nobody ?
A 2mn search shows this:
https://ipcamtalk.com/threads/vto2000a-rest-api.38867/
Looks there is no way to setup, for instance, some http command that may drive a domoticz (virtual) switch through JSON API. So only some pooling may be done programmatically.
But according to this message, alarm output on the device may be used to drive a device able to report ring button status? At the end, another option looks to be using FTP snapshots upload configuration when someone rings, by monitoring a ftp server on PI side.
Dahua may have been smarter on this, by allowing setup a http command to be sent on rings... Not being a coder, forget this.
Posted: Sunday 17 October 2021 19:37
by hoeby
Found this, maybe it opens an option
https://github.com/elad-bar/DahuaVTO2MQTT
Didn't looked deep in it. Don't know if docker is needed or optional, mqtt is needed
