Zigbee plugin dont show up in hardware after installation
Posted: Thursday 30 September 2021 13:36
by LordMax
Hi!
I am trying to get my HubZ Zigbee adapter to work in domoticz. I have got the drivers successfully installed and I have downloaded the "zigbee2mqtt" plugin. I am running domoticz on Windows and I have Python 3.9 downloaded. The plugin is stored inside the plugins folder but it doesnt show up in hardware and no error is found. I have given the plugin.py full premissions but nothing still happens. Thanks beforehand!
Best regards Max
Re: Zigbee plugin dont show up in hardware after installation
Posted: Thursday 30 September 2021 21:02
For windows use python 3.8 instead of 3.9 as 3.9 is not yet supported by Domoticz.
Posted: Thursday 30 September 2021 22:23
by LordMax
waltervl wrote: Thursday 30 September 2021 21:02
Hi!
I have tried almost every version, I have another post where I was more clear that I cannot get any plugin to show up because of the error
Failed dynamic library load, install the latest libpython3.x library that is available for your platform.
But check that post out here:
viewtopic.php?f=28&t=37090
Posted: Friday 01 October 2021 0:01
It should work. See also
viewtopic.php?f=65&t=27569
What do you see about python in menu setup- about domoticz?
Posted: Friday 01 October 2021 10:25
by LordMax
I cannot find anything in #/setup/ for python, in the post you linked they said that you could modyfy this:
If you build from source you could try it out by adding a line to/hardware/plugins/DelayedLink.h ~line 190
but I cannot find that file. Still the same error after reinstallation. But the extra weird thing is that when I reinstall python the first time I boot domoticz it cannot be reached. I have to do another restart to be able to connect to it..
Posted: Friday 01 October 2021 12:19
Did you install Python 3.8.5 as an administrator? Did you check the "for all users" on?
Posted: Friday 01 October 2021 12:53
by LordMax
waltervl wrote: Friday 01 October 2021 12:19
Yes I did, I have tried a couple of different versions such as 3.5.2, 3.5.3, 3.8.5. But still the same error..
Posted: Sunday 03 October 2021 15:10
by LordMax
It had to be installed in program files x86 instead of users!!
