Sync 2 Zwave dimmers
Posted: Thursday 30 September 2021 8:39
Hi everybody.
I'am looking to sync 2 dimmers FGD-212
the first dimmer is for the front house with a simple bistable Switch .
the second is for the back house with a blind monostable switch on s1 an s2.
All is working fine.
But I want to group them. (either use the blind switch, or switch)
I've tried this LUA script :
viewtopic.php?t=19217
with this parameter
2185|2|1921|F00
src 2way dest dimmer
It works but if I can't put the switch at 100% ( if I select 1-99% the 2 dimmers are synchronised fine but If I go to 100%, the 2 dimmers switch to off. )
In the zwave configuration panel, If I use the "Instance 1: Level" on whatever the dimmer, I can use only 1-99 values, so I think It can be the matter...
Maybe I'am wrong but I think that I can't use directly the zwave groups, as the both confs are not the same... ( monostable on one, bistable on the other)
Do you have some idea, or a better solution to sync the dimmers?
with this parameter
2185|2|1921|F00
