dzVents script from web editor doesn't change
Posted: Thursday 16 September 2021 20:14
by Huupke
Hi all.
I recently noticed that in my setup changing a dzVents script in the web editor doesn't update the script that is actually being parsed and run. I have to change the name of the script ('filename') to actually see my latest changes to be used by the runtime/parser. When I change the name of the script back to the original name the script also revert to an old version.
Rebooting the host (Pi3b) or changing the (logging) marker didn't work.
I checked in the filesystem that the filename is properly changing and also old files are being removed. Is there somewhere a cache that I can purge? Is this a known issue?
Re: dzVents script from web editor doesn't change
Posted: Thursday 16 September 2021 21:17
That is strange indeed. I never had this issue. The files are also refreshed every night at 24.00 hours. At every save all dzVents scripts from the web event system are updated and stored on the file system, see the log file for the location.
Perhaps you browser cache needs to be refreshed? Or try it with the browser in incognito/privacy mode.
