Moes 4 button switch
Posted: Monday 13 September 2021 21:29
by snuiter
I have received the 4 button switch from Moes/Tuya. Anyone has this one working?
It is seen in zigbee2mqtt frontend and Domoticz but each button only has one function, so only have 4 functions in total (on/off/brightness step_up/..._down)
Anyone has an idea if each button can be seen as a seperate switch where each switch has something like single/double/long click?
This way I can assign different functions per button.
Thanks for any help
Re: Moes 4 button switch
Posted: Monday 13 September 2021 21:34
by EddyG
Is it this switch?
https://www.zigbee2mqtt.io/devices/TS0601_switch.html
It has 4 endpoints and each has 3 states. So nothing about single, double and long click.
Posted: Monday 13 September 2021 22:10
by snuiter
unfortunately not, but that behaviour would be nice indeed
It is this switch
Just a square, divided into 4 smaller equal squared buttons
Posted: Tuesday 14 September 2021 7:57
by EddyG
So it is this one:
https://www.zigbee2mqtt.io/devices/TS00 ... uya-ts0044
On that page you can also see what that device exposes.
I have that device and it works perfectly and has single/double/hold on each button.
Posted: Tuesday 14 September 2021 21:35
by snuiter
Well it is actually this one:
https://www.zigbee2mqtt.io/devices/TS00 ... uya-ts004f
So google shows that both models are shipped so you don't know which one you get, but the behaviour of the buttons is different.
Any idea how this can be changed ?
Posted: Tuesday 14 September 2021 23:45
by waltervl
Never heard that you can change the behavior of a ZigBee device. The only way could be to flash some kind of other firmware. Perhaps google will give a solution.
Or buy a new one and hope they will send the good version
Posted: Wednesday 15 September 2021 10:42
by EddyG
Would have been nice if you put that device link in your first post, that way I would not have to guess wrong twice.
Which device (name/type) is presented in the zigbee2mqtt logging?
Posted: Wednesday 15 September 2021 21:12
by snuiter
EddyG wrote: Wednesday 15 September 2021 10:42
You are right but I did not find the device as I looked for Moes but I see there are 2 on Tuya, hence my mistake.
Model listed in the zigbee log and on the zigbee2mqtt frontpage is : model_id":"TS004F"
