Zigate OTA update Ikea Tradfri
atmfrenki
Post by atmfrenki »
I tried updating the firmware for my Ikea Tradfri Devices through the Zigate Plugin (USBzigate+ V2, Plugin: 5.1.009, Firmware: 0320)
Unfortunately, i can't get it to work.
I followed this manual:
https://github.com/pipiche38/Domoticz-Z ... irmware.md
Through this manual I followed the steps, only at step 4 I found out that in the latetst Zigate-Plugin versions the OTA is already active and is not a selectable option anymore. (right?)
Than I tried to force an update to a Ikea Lightbulb.
This is the result:
I always receive a Timeout, I tried 2 different Lightbulbs and 2 different firmware's.
Does anybody have a tip on how to get this working?
Frenki
pipiche
Re: Zigate OTA update Ikea Tradfri
Post by pipiche »
If your bulb is a Tradfri GU10 WS 400lm then the image type to select is 0x2203 and the latest version is 2.3.050.
Thanks to Dresden maintaining that list
https://github.com/dresden-elektronik/d ... e-versions
Is the firmwae upgrading starting, do you see for instance in the log something like
Firmware transfert for dfc2/01 - Progress: 0.0 %
pipiche
Post by pipiche »
Looks like there is a Bug in the Zigate+ (V2) firmware which prevent device OTA firmware
atmfrenki
Post by atmfrenki »
Ok thanks,
No I don't see any progress bar.
Before the ultimate timeout I get these in the eventlog:
2021-09-13 17:11:09.101 Zigate: (Zigate) Ota retries notifying device 147a
pipiche
Post by pipiche »
atmfrenki wrote: Monday 13 September 2021 17:12 Ok thanks,
I duplicate your problem and reported to Zigate https://github.com/fairecasoimeme/ZiGatev2/issues/23
marktn
Post by marktn »
Is there a reason to update when there is no problem?
Domoticz latest stable, Intel NUC, Proxmox, Zigate, RFLink, Kaku switches, Ikea lights, Xiaomi sensors, Honeywell smoke detectors, Yeelight, Shelly, Slave Domoticz PI 3B+, Node-Red, Espeasy.
atmfrenki
Post by atmfrenki »
pipiche wrote: Monday 13 September 2021 18:01
Thank you very much!!
pipiche
Post by pipiche »
Can you try the following:
1- stop the plugin
2- unplug the USB ZIGate for 10s and then plug in it back
3- restart the plugin
try the OTA firmware
atmfrenki
Post by atmfrenki »
Unfortunately no positive effect:
Result:
2021-09-22 13:41:14.104 Error: ZigateV2: (ZigateV2) Ota detects Timeout while notifying device 9758
Frenki
pipiche
Post by pipiche »
do you have any means to sniff the Zigbee traffic ?
