zigbee2mqtt error
Posted: Friday 10 September 2021 20:55
I keep seeing this in my logfile:
2021-09-10 20:47:43.305 Error: Zigbee: (Zigbee2MQTT) failed to load 'plugin.py', Python Path used was '/home/pi/dev-domoticz/plugins/zigbee2mqtt/:/usr/lib/python37.zip:/usr/lib/python3.7:/usr/lib/python3.7/lib-dynload:/usr/local/lib/python3.7/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.7/dist-packages'.
2021-09-10 20:47:43.305 Error: Zigbee: (Zigbee) Module Import failed, exception: 'ModuleNotFoundError'
2021-09-10 20:47:43.305 Error: Zigbee: (Zigbee) Module Import failed: ' Name: DomoticzEx'
2021-09-10 20:47:43.305 Error: Zigbee: (Zigbee) Error Line details not available.
I run Domoticz version 2021.1 and use zigbee2mqtt plugin version 3.1.0-beta. Also the "custom" menu bar at the top is gone (was only showing "loading").
Any help would be appriciated.
