Homenickb wrote: Thursday 02 September 2021 7:20I keep reading about how awful WiFi repeaters are
like the other contributors said, it depends on your actual router and repeater.
If you want an ananlogy to understand what's going on : Wifi is like a one way street (it can have more than one lane though, but assume there is only one lane). The network traffic is like cars, if you have one car on the road, you can't have another one (even in the opposition direction).
So when using a repeater, instead of two cars using the road (your PC and your router), you add another one : the repeater. So you are reducing the traffic on the road immediately (up to 50%) because every trip your PC car is making, the repeater car will do the same. The more device cars you have on that road, the more congested the road will be.
That's why it's usually better to not use them and the proper way to extend Wifi coverage is to wire a new acces point to your router, the wire could be an Ethernet cable, a power line etc... as all other contributors advised you.
However : be careful when adding another access point. If your apartment is not huge, chances are great that wifi coverage of the router and the AP will overlap : and your are back to the one road problem, if router and access point use the same channel... so you have to make sure to use a different channel and choose the location with the least overlap.
Also : sometimes it's only your router that is really bad at Wifi, especially it this router is the one offered by your ISP. Upgrading to a new router can solve the issue, and if you can go with a mesh solution (wifi mesh is like adding a wired access point, instead wireless, it's better than repeater, because each access point is aware of each other and know how to share Wifi optimally; often they use a dedicated frequency to talk to each other, so they eliminate the one road problem, by using two or threed roads)
