EnOcean D2-01-0C not handled
Posted: Monday 30 August 2021 17:14
I'm not a new domoticz's user but it's the first time a device doesn't work.
I don't know how to do neither whom asking ...
Regards.
Version: 2021.1
Platform: Ubuntu 20.04.3 LTS, GNOME : 3.36.8
Plugin/Hardware: EnOcean USB (ESP3)
2021-08-30 17:04:06.397 Status: EnOcean: Worker started...
2021-08-30 17:04:06.601 Status: EnOcean: Using serial port: /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_AU03KVTY-if00-port0
2021-08-30 17:04:06.601 Status: EnOcean: EnOcean Send: 55 00 01 00 05 70 08 38
2021-08-30 17:04:06.601 Status: EnOcean: EnOcean Send: 55 00 01 00 05 70 03 09
2021-08-30 17:04:06.676 Status: EnOcean: 02 (05/01) 00 FF AC A7 80 0A
2021-08-30 17:04:06.676 Status: EnOcean: Transceiver ID_Base: 0xffffffffffaca780
2021-08-30 17:04:06.876 Status: EnOcean: 02 (21/00) 00 02 0F 00 00 02 06 09 00 05 1D 59 4F 45 4F 01 03 47 41 54 45 57 41 59 43 54 52 4C 00 00 00 00 00
2021-08-30 17:04:06.876 Status: EnOcean: Version_Info, App: 02.0f.00.00, API: 02.06.09.00, ChipID: 05.1d.59.4f, ChipVersion: 45.4f.01.03, Description: GATEWAYCTRL
Device : D2-01-0C
2021-08-30 17:09:19.435 EnOcean: destination: 0xffffffff RSSI: -68 dBm (6/11)
2021-08-30 17:09:19.435 EnOcean: teach-in request received from 04120EBE (manufacturer: 046). number of channels: 1, device profile: D2-01-0C
2021-08-30 17:09:19.436 EnOcean: Sender_ID 0x04120EBE inserted in the database
2021-08-30 17:09:19.435 Status: EnOcean: 01 (0D/07) D4 A0 01 46 00 0C 01 D2 04 12 0E BE 00 00 FF FF FF FF 44 00
2021-08-30 17:09:20.492 EnOcean: destination: 0xffffffff RSSI: -67 dBm (6/11)
2021-08-30 17:09:20.492 EnOcean: teach-in request received from 04120EBE (manufacturer: 046). number of channels: 1, device profile: D2-01-0C
2021-08-30 17:09:20.492 EnOcean: Sender_ID 0x04120EBE already in the database
2021-08-30 17:09:20.492 Status: EnOcean: 01 (0D/07) D4 A0 01 46 00 0C 01 D2 04 12 0E BE 00 00 FF FF FF FF 43 00
2021-08-30 17:09:21.548 EnOcean: destination: 0xffffffff RSSI: -67 dBm (6/11)
2021-08-30 17:09:21.548 EnOcean: teach-in request received from 04120EBE (manufacturer: 046). number of channels: 1, device profile: D2-01-0C
2021-08-30 17:09:21.548 EnOcean: Sender_ID 0x04120EBE already in the database
2021-08-30 17:09:21.548 Status: EnOcean: 01 (0D/07) D4 A0 01 46 00 0C 01 D2 04 12 0E BE 00 00 FF FF FF FF 43 00
2021-08-30 17:09:22.018 EnOcean: Lighting 2 ()
2021-08-30 17:09:22.154 EnOcean: destination: 0xffffffff RSSI: -67 dBm (6/11)
2021-08-30 17:09:22.154 EnOcean: Sender_ID 0xFFFFFFFFFFACA782 inserted in the database with default profile F6-02-01
2021-08-30 17:09:22.154 EnOcean: If your Enocean RPS device uses another profile, you must update its configuration.
2021-08-30 17:09:22.155 EnOcean: Lighting 2 (Unknown)
2021-08-30 17:09:22.354 EnOcean: destination: 0xffffffff RSSI: -67 dBm (6/11)
2021-08-30 17:09:22.355 EnOcean: Lighting 2 (Unknown)
2021-08-30 17:09:22.016 Status: User: Admin (IP: 192.168.1.9) initiated a switch command (1/Fil Pilotte/On)
2021-08-30 17:09:22.017 Status: EnOcean: EnOcean Send: 55 00 07 00 01 11 F6 10 FF AC A7 82 30 93
2021-08-30 17:09:22.017 Status: EnOcean: EnOcean Send: 55 00 07 00 01 11 F6 00 FF AC A7 82 20 7D
2021-08-30 17:09:22.154 Status: EnOcean: 02 (01/00) 00
2021-08-30 17:09:22.154 Status: EnOcean: 01 (07/07) F6 10 FF AC A7 82 31 00 FF FF FF FF 43 00
2021-08-30 17:09:22.354 Status: EnOcean: 02 (01/00) 00
2021-08-30 17:09:22.354 Status: EnOcean: 01 (07/07) F6 00 FF AC A7 82 21 00 FF FF FF FF 43 00
2021-08-30 17:11:22.823 EnOcean: Lighting 2 (Unknown)
2021-08-30 17:11:22.881 EnOcean: destination: 0xffffffff RSSI: -70 dBm (6/11)
2021-08-30 17:11:22.881 EnOcean: EnOcean message VLD: Profile: 01 Type: 0C
2021-08-30 17:11:22.881 EnOcean: EnOcean message VLD: func: 02 Type: 40
2021-08-30 17:11:22.881 EnOcean: Unhandled RORG (d2)
2021-08-30 17:11:22.881 EnOcean: Lighting 2 (Unknown)
Specification : http://tools.enocean-alliance.org/EEPVi ... -01-0C.pdf
Regards.
Version: 2021.1
Device : D2-01-0C
