Switch On/Off with notify
Posted: Friday 13 August 2021 11:53
by Bospieper
I have a Woox irrigation switch wich I want to change it's status from "Off" to "On" with a delay time of 15 minutes to "Off" status on a fixed time every day and I want for every status(On or Off) be notifyed bij a Pushover message.
I'am struggeling with the "Off" status and the "Off status" notify.
I would appriciate if someone can point me in the right direction of the program.
Thanks in advance.
Piet
Re: Switch On/Off with notify
Posted: Friday 13 August 2021 13:28
Do you get a notification by another method when the device is switched off due to the delay?
Or do you get no notification at all.
Do you get a notification when you manually (through user interface) switch off the switch?
Is pushover notification system working in Domoticz?
https://www.domoticz.com/wiki/Managing_ ... ifications
Posted: Friday 13 August 2021 17:21
by Bospieper
Yes, Pushover notifications works also in Domoticz, I have manualy tested it.
I am receiving no notification at all when the switch is turned to Off status after delay.
