Trying to let virtual dimmer change background color
Posted: Thursday 12 August 2021 11:01
Guys I need some help, I'm trying for a week now but cannot get this to work
I have two philips huelights as RGBWW devices *idx 42 and 43). I have a script that calculates the colortemperature according to time-of-day and set it every minute.
Then i read the colortemperature t and calculate that back to Kelvin (0-100) and put that value to set a virtual device: Dimmer (idx 44). So that dimmer will slowly 'walk' from 0 to 100
Now i already have some blocks in Dashticz change color according to values and using addClass
What i would like to do now is let the block (preferable the slider) to change to the color in Dashticz that the light has in real.
I saw this script in custom.js:
Unfortunately its not working
Than I reprogrammed to this (also custom.js):
with and without the else staement and else with and witout curly brackets
Didnt work
Than i tried this custom.js:
together with this custom.css:
Where the hex codes are calculated as to be approximates of the color that moment
This also doesnt change anything at all. Also tried
Domoticz.getAllDevices()[44].Data
Domoticz.getAllDevices()[44].Level
Domoticz.getAllDevices()[44].level
What am i doing wrong??
function getStatus_44(block){
var color = JSON.parse(block.device.Color);
if (block.device.Data!='Off') {
var yellow=255;
var blue=255;
if (color.ww>128) //very warm, so reduce blue
blue = 255 - color.ww/2+64;
if (color.cw>128) //very cold, so reduce yellow
yellow = 255 - color.cw/2+64;
var colorStr = `rgb(${yellow},${yellow},${blue})`;
$(block.mountPoint + ' > div').css('background-color', colorStr)
$(block.mountPoint + ' > div').css('background-color', '')
}Than I reprogrammed to this (also custom.js):
//function getStatus_42(block){
var devices = Domoticz.getAllDevices();
var couch = devices[42];
var kleur = parseInt(couch.Color);
if (couch.State=='Set Color') {
var yellow=255;
var blue=255;
if (kleur.ww>128) //very warm, so reduce blue
blue = 255 - kleur.ww/2+64;
if (kleur.cw>128) //very cold, so reduce yellow
yellow = 255 - kleur.cw/2+64;
$(block.mountPoint + ' > div').css('background-color', colorStr);
//else {
// $(block.mountPoint + ' > div').css('background-color', '');
//}Didnt work
3 function getStatus_44(block){
4 var Data = Domoticz.getAllDevices()[44].Data.Level
5 var addClass;
6 if(parseFloat(Data) >90){
7 addClass='bovennegentig';
8 }
9 else if(parseFloat(Data) >80){
10 addClass='boventachtig';
11 }
12 else if(parseFloat(Data) >70){
13 addClass='bovenzeventig';
14 }
15 else if(parseFloat(Data) >60){
16 addClass='bovenzestig';
17 }
18 else if(parseFloat(Data) >50){
19 addClass='bovenfijvtig';
20 }
21 else if(parseFloat(Data) >40){
22 addClass='bovenveertig';
23 }
24 else if(parseFloat(Data) >30){
25 addClass='bovendertig';
26 }
27 else if(parseFloat(Data) >20){
28 addClass='boventwintig';
29 }
30 else if(parseFloat(Data) >10){
31 addClass='boventien';
32 }
33 else if(parseFloat(Data) >0){
34 addClass='bovennul';
35 }
36 else {
37 addClass='none';
38 }
39 block.addClass = addClass;
40 }
/* classes for hanging color on kelvin color slider */
37 .bovennegentig {
38 background: #FF9F46
39 }
40 .boventachtig {
41 background: #FFAC63
42 }
43 .bovenzeventig {
44 background: #FFB87B
45 }
46 .bovenzestig {
47 background: #FFC18D
48 }
49 .bovenfijvtig {
50 background: #FFCEA6
51 }
52 .bovenveertig {
53 background: #FFDABB
54 }
55 .bovendertig {
56 background: #FFE4CE
57 }
58 .boventwintig {
59 background: #FFEDDE
60 }
61 .boventien {
62 background: #FFF6ED
63 }
64 .bovennul {
65 background: #FFFEFA
66 }This also doesnt change anything at all. Also tried
