Doorlock block not working
colint
Post by colint »
Hello all,
I am working on Dashticz with Fully Kiosk.
My problem is the Door-lock.
When i set it up as a door-lock in domoticz. If i control it through domoticz it updates the status in dashticz.
But if i want to control it with dashticz it does not work.
When i change the door-lock in domoticz to "on/off" it works, but this is not what i want.
How can i get it to work as a door-lock instead as a light-switch?
Thanks,
Colin
Lokonli
Re: Doorlock block not working
Post by Lokonli »
Until now a door lock behaved as read-only.
I've changed this in latest beta. A door lock now behaves like a regular switch.
You can disable switch behavior by adding 'protected: true' as block parameter.
colint
Post by colint »
Hello Lokonii,
thank for the explanation.
i have made a work-a-round for it with a dummy and a script to sync it with the doorlock.
