I'm a happy Domoticz user for many years - BUT I have recently added the possibility to monitor status from my Kamstrup Omnipower 3 phase electric meter.
My problem is how to present the data nicely in Domoticz - zoomable graphs for 3 phase voltage, amps and power to name a few.
Yes I know I can have a graph for each phase, but not really a nice solution...
Wouldn't it make sense to add some kind of generic dummy device to Domoticz with options to have multible data sets and graph options to show them?
Would be nice to be able to show both voltage, amps and power in same graph with multiple y-axis..
BR,
M
Dummy device with generic graph option
- Domoticz version: 2026.3
Re: Dummy device with generic graph option
The problem probably is that there is no 3 Phase electricity device within Domoticz.
So that first has to be programmed and then the graphs.
As a workaround you could try to use Grafana to combine all Domoticz values in a combined Grafana graph. It will need some special SQL programming.
https://domoticz.com/forum/viewtopic.php?f=21&t=35101
