Battery Level checker
akamming
Post by akamming »
just 2 share: made a small script which will notify me if battery powered devices are running low on battery
		devices = {
			'test'    -- put in any manual trigger you want to do for the dives
		timer = {
		    'at 20:00', -- when you want 2 run the script
	logging = {
		level = domoticz.LOG_INFO,
		marker = 'Battery',
	    domoticz.log("Started",domoticz.LOG_DEBUG)
        domoticz.devices().forEach(function(device)
            if (device.batteryLevel) then
                domoticz.log("device "..device.name.." has batterylevel "..device.batteryLevel.."%",domoticz.LOG_DEBUG)
                if (device.batteryLevel < 15) then   -- set to whatever treshold you like
                    domoticz.log("Device "..device.name.." has low batterylevel ("..device.batteryLevel.."%)",domoticz.LOG_INFO) -- change notification logline to suit your needs
                    domoticz.notify(device.name,"Batterij moet vervangen worden ("..device.batteryLevel.."%)",domoticz.PRIORITY_NORMAL) -- change notification message to suit your needs
        end)
Confirmed to work with OpenZWave battery levels.
user4563
Domoticz version: 2026.4
Re: Battery Level checker
Post by user4563 »
Thank you for this!!
I did change line:
to
if (device.batteryLevel <= 40 and device.batteryLevel > 0 and device.batteryLevel ~= nil)
just to filter out those devices that report 0 or nil
Aeotec Z-Stick Gen5+
ZWave-JS-UI / Mosquitto MQTT
Domoticz for Android
