new 2gig CT100...
Posted: Wednesday 15 October 2014 19:08
Got a 2gig CT100 (aka, Radio Thermostat CT100, FCC ID Q08-CT100R1, IC 4714A-CT100R1)
First, a simple change was needed to manufacturer_specific.xml:
<Product type="6401" id="0107" name="CT100 Thermostat" config="2gig/ct100.xml"/>
They changed the ID from 105 to 107.
I also get this on startup:
I added some code to see what the values are, and got these:
Things I've found out so far:
Fri Oct 10 14:10:24 2014 OpenZWave: Value_Added: Node: 9, CommandClass: CLOCK, Label: Day, Instance: 1
Fri Oct 10 14:10:24 2014 Error: OpenZWave: Unhandled class: 0x81 (CLOCK)
Fri Oct 10 14:10:24 2014 OpenZWave: Value_Added: Node: 9, CommandClass: CLOCK, Label: Hour, Instance: 1
Fri Oct 10 14:10:24 2014 OpenZWave: Value_Added: Node: 9, CommandClass: CLOCK, Label: Minute, Instance: 1
Fri Oct 10 14:10:24 2014 OpenZWave: Value_Added: Node: 9, CommandClass: INDICATOR, Label: Indicator, Instance: 1
Fri Oct 10 14:10:24 2014 Error: OpenZWave: Unhandled class: 0x87 (INDICATOR)
Fri Oct 10 14:10:24 2014 OpenZWave: Value_Added: Node: 9, CommandClass: THERMOSTAT OPERATING STATE, Label: Operating State, Instance: 1
Fri Oct 10 14:10:24 2014 Error: OpenZWave: Unhandled class: 0x42 (THERMOSTAT OPERATING STATE)
Fri Oct 10 14:10:24 2014 OpenZWave: Value_Added: Node: 9, CommandClass: THERMOSTAT FAN STATE, Label: Fan State, Instance: 1
Fri Oct 10 14:10:24 2014 Error: OpenZWave: Unhandled class: 0x45 (THERMOSTAT FAN STATE)
Fri Oct 10 14:10:24 2014 OpenZWave: Value_Added: Node: 9, CommandClass: BATTERY, Label: Battery Level, Instance: 1
Fri Oct 10 14:10:30 2014 Hardware Monitor: Fetching data (System sensors)
Fri Oct 10 14:10:31 2014 OpenZWave: Value_Added: Node: 9, CommandClass: THERMOSTAT MODE, Label: Mode, Instance: 1
Fri Oct 10 14:10:31 2014 Error: OpenZWave: Unhandled class: 0x40 (THERMOSTAT MODE)
Fri Oct 10 14:10:32 2014 OpenZWave: Value_Added: Node: 9, CommandClass: THERMOSTAT SETPOINT, Label: Heating 1, Instance: 1
Fri Oct 10 14:10:32 2014 OpenZWave: Value_Added: Node: 9, CommandClass: THERMOSTAT SETPOINT, Label: Cooling 1, Instance: 2
Fri Oct 10 14:10:33 2014 OpenZWave: Value_Added: Node: 9, CommandClass: THERMOSTAT FAN MODE, Label: Fan Mode, Instance: 1
Fri Oct 10 14:10:33 2014 Error: OpenZWave: Unhandled class: 0x44 (THERMOSTAT FAN MODE)
Wed Oct 15 09:47:02 2014 OpenZWave: Value_Added: Node: 9, CommandClass: SENSOR MULTILEVEL, Label: Temperature, Instance: 1
Wed Oct 15 09:47:02 2014 OpenZWave: Value_Added: Node: 9, CommandClass: SENSOR MULTILEVEL, Label: Temperature, Instance: 2
Wed Oct 15 09:47:02 2014 OpenZWave: Value_Added: Node: 9, CommandClass: SENSOR MULTILEVEL, Label: Relative Humidity, Instance: 5
Wed Oct 15 09:47:02 2014 OpenZWave: Value_Added: Node: 9, CommandClass: THERMOSTAT OPERATING STATE, Label: Operating State, Instance: 1
Wed Oct 15 09:47:02 2014 Operating State: Heating
Wed Oct 15 09:47:02 2014 OpenZWave: Value_Added: Node: 9, CommandClass: THERMOSTAT SETPOINT, Label: Heating 1, Instance: 1
Wed Oct 15 09:47:02 2014 OpenZWave: Value_Added: Node: 9, CommandClass: THERMOSTAT SETPOINT, Label: Cooling 1, Instance: 2
Wed Oct 15 09:47:02 2014 OpenZWave: Value_Added: Node: 9, CommandClass: THERMOSTAT FAN MODE, Label: Fan Mode, Instance: 1
Wed Oct 15 09:47:02 2014 Fan Mode: Auto Low
Wed Oct 15 09:47:02 2014 OpenZWave: Value_Added: Node: 9, CommandClass: THERMOSTAT FAN STATE, Label: Fan State, Instance: 1
Wed Oct 15 09:47:02 2014 Fan State: Idle
Wed Oct 15 09:47:02 2014 OpenZWave: Value_Added: Node: 9, CommandClass: BATTERY, Label: Battery Level, Instance: 1
Wed Oct 15 09:47:02 2014 OpenZWave: Value_Added: Node: 9, CommandClass: CLOCK, Label: Day, Instance: 1
Wed Oct 15 09:47:02 2014 Day: Tuesday
Wed Oct 15 09:47:02 2014 OpenZWave: Value_Added: Node: 9, CommandClass: CLOCK, Label: Hour, Instance: 1
Wed Oct 15 09:47:02 2014 Hour: 10
Wed Oct 15 09:47:02 2014 OpenZWave: Value_Added: Node: 9, CommandClass: CLOCK, Label: Minute, Instance: 1
Wed Oct 15 09:47:02 2014 Minute: 51
Wed Oct 15 09:47:02 2014 OpenZWave: Value_Added: Node: 9, CommandClass: INDICATOR, Label: Indicator, Instance: 1
Wed Oct 15 09:47:02 2014 Indicator: 0
- You can change the setpoint via web interface, but not by blocky.
- Every time domoticz startups/restarts, it re-adds temperature devices..
