Deactivate timers in heating thermostats
harrykausl
Domoticz version: 2021.1
Post by harrykausl »
For heating regulation I use timers in the thermostats. Sometimes I have to deactivate the timers for one or for all thermostats or activate them. I‘m using a lua scrpt with the hardcoded timer-ids. Would it be possible to insert a switch in the thermostat device to activate or deactivate all timers for this device. It also should be possible to change this switch via script.
Re: Deactivate timers in heating thermostats
You are aware of timer plans? https://www.domoticz.com/wiki/Timer_Plan
This at least will give you the opportunity to switch to another timer schedule for all devices eg holiday schedule or away schedule.
