switching alarm panel Topic is solved
JuanUil
Domoticz version: 4.11083
Post by JuanUil »
I am trying to switch the domoticz security panel in lua.
I tried:
if (devicechanged['Thuis'] == 'Off') then
	print ('testing')
	commandArray['Security Panel'] = 'Arm Away'
no result
	print ('testing')
	commandArray['Alarm Panel'] = 'Arm Away'
no result
	print ('testing')
	commandArray['SecPanel'] = 'Arm Away'
no result
anyone any idea what i am doing wrong?
AllesVanZelf
Domoticz version: 12467
Re: switching alarm panel
Post by AllesVanZelf »
I think you have to use: security.armAway()
See: wiki
and search for: Security Panel
JuanUil
Post by JuanUil »
AllesVanZelf wrote: Wednesday 14 July 2021 15:32 I think you have to use: security.armAway()
See: wiki
I am using LUA not Dzvents so this is not working.
AllesVanZelf
Okay, sorry. Missed that part.
In this topic https://domoticz.com/forum/viewtopic.ph ... el#p247937
the security panel is called "Domoticz Security Panel"
JuanUil
Post by JuanUil »
waltervl wrote: Thursday 15 July 2021 9:06 In this topic https://domoticz.com/forum/viewtopic.ph ... el#p247937
thnx for yourreply but also not working, alarm panel isn't switched. :?:
In this topic also some interesting tips about this issue: https://domoticz.com/forum/viewtopic.php?f=61&t=1785
Can you manually set the security panel (with the PIN code)?
JuanUil
Post by JuanUil »
found the problem!
The panel was not in the devices tab.
So I changed the code, armed and disarmed it manually. then the panel appeared in the devices tab and I could use it in my LUA script.
Thanx everybody.
lost
Post by lost »
JuanUil wrote: Thursday 15 July 2021 12:59 found the problem!
Just take care that string used to check security panel status is different than the one to change it, for instance:
Check if Disarmed :
devicechanged[devSecPanel] == 'Normal'
Set status (if may be done by something external to secpanel, script, BT/Wifi presence detection using smartphones...):
commandArray[devSecPanel] = 'Disarm'
(To arm, this would be setting 'Arm Away').
This tricked me a few times...
