How to detect if a device is online
Posted: Tuesday 29 June 2021 11:50
by Wolly76
I would like to test if a device is online. More specifically a WiFi light bulb. I could retrieve the last-updated-time as well as the state, but both parameter give normal values when the device is on or offline (power is off).
A method might be to ping on the IP address but I couldn't find a way to retrieve the IP address of a certain device as it is handled using MQTT.
Domoticz itself adds a red bar on the device when it is offline, but how to get this information in dzVentz?
Does anybody know how to achieve this?
Thanks in advance.
Regards, Wolly
Re: How to detect if a device is online
Posted: Tuesday 29 June 2021 15:50
It should be the .timedOut device attribute that indicates that.
https://www.domoticz.com/wiki/DzVents:_ ... ll_devices
Posted: Wednesday 30 June 2021 14:19
by Wolly76
Great! thanks. Life can be so easy, sometimes.
Posted: Friday 25 August 2023 8:49
by ssk17051980
did you find a solution to find if a device it's offline ?
thx
