Migrating to Docker - JSON.lua not working
PVuser
Domoticz version: 2021.1
Post by PVuser »
I migrated to Docker via Backup and Restore. All seems to work fine but my Fronius script. There I need to load JSON.lua
The orignial line was:
JSON = (loadfile '/home/pi/domoticz/scripts/lua/JSON.lua')()
Now I tried:
JSON = (loadfile '/opt/domoticz/scripts/lua/JSON.lua')()
and it seems to load. But I didn't get my data out of the fronius data with json. And I don't know any way to get deeper to find the error!
The part of code:
   JSON = assert(loadfile '/opt/domoticz/scripts/lua/JSON.lua')()   -- For Linux
   if debug then print('JSON ~= nil?') end
   if debug then print("JSON: "..tostring(JSON~=nil)) end
      -- Extract data from Fronius using API v1
      -- from https://www.fronius.com/en/photovoltaics/products/all-products/system-monitoring/open-interfaces/fronius-solar-api-json-
      froniusURL   = 'curl "http://'..IPFronius..'/solar_api/v1/GetPowerFlowRealtimeData.fcgi"'
      jsonData    = assert(io.popen(froniusURL))
      froniusDevice = jsonData:read('*all')
      jsonData:close()
      froniusData = JSON:decode(froniusDevice)
      if debug then print("froniusData: "..tostring(froniusData~=nil)) end
      if debug then print("froniusData: "..tostring(froniusData)) end
And the debug output show me, that JSON is loaded, but froniusData is nil. I didn't change the code itself. Is there a change from Domoticz (2020.2/python 3.7.3) to current version?
 2021-06-27 16:46:22.360 Status: LUA: JSON ~= nil?
2021-06-27 16:46:22.360 Status: LUA: JSON: true
2021-06-27 16:46:22.371 Status: LUA: froniusData: false
2021-06-27 16:46:22.371 Status: LUA: froniusData: nil
I hope anyone can help me
Re: Migrating to Docker - JSON.lua not working
PVuser
Post by PVuser »
Thanks, but this isn't the solution. I did:
cp -r /opt/domoticz/scripts/lua /opt/domoticz/dzVents/runtime
and also checked, that copy was fine. And tried both, the old path and the new path
/opt/domoticz/dzVents/runtime.
None of this works.
And as you can see in the output I posted (it's still the same), the variable JSON was not nil, so I assume, that JSON was correct loaded!???
PVuser
Post by PVuser »
Is there another way to check, if JSON is loaded correctly? I think this will be the first entry point to narrow the error. But than I have no other idea, because the code is the same as in previoous domoticz version.
with:
      if debug then print("jsonData: "..tostring(jsonData)) end
I get the output:
2021-07-02 11:43:43.761 Status: LUA: jsonData: file (0x72c18510)
So it seems, that opening is also ok?
And
     if debug then print("froniusDevice: "..tostring(froniusDevice)) end
result in:
2021-07-02 11:46:13.108 Status: LUA: froniusDevice:
PVuser
Migrating to Docker - curl doesn't work
Post by PVuser »
Does nobody have an idea?
I'm sure now, that the error is in
The file content is empty! But why does it work outside a container?
is curl installed in the docker container?
Did you try to run the command from the command prompt in the docker container to see what kind of error you get?
PVuser
Migrating to Docker - How to install curl
Post by PVuser »
many thanks @waltervl - thats it. But how to install??
Try to use it inside docker (via portainer) I get:
root@6570a7555a37:/opt/domoticz# curl "http://192.168.178.200/solar_api/v1/GetPowerFlowRealtimeData.fcgi"
bash: curl: command not found
root@6570a7555a37:/opt/domoticz# apt-get update
Err:1 http://deb.debian.org/debian buster InRelease
  Temporary failure resolving 'deb.debian.org'
Err:2 http://security.debian.org/debian-security buster/updates InRelease
  Temporary failure resolving 'security.debian.org'
Err:3 http://deb.debian.org/debian buster-updates InRelease
Reading package lists... Done
W: Failed to fetch http://deb.debian.org/debian/dists/buster/InRelease  Temporary failure resolving 'deb.debian.org'
W: Failed to fetch http://security.debian.org/debian-security/dists/buster/updates/InRelease  Temporary failure resolving 'security.debian.org'
W: Failed to fetch http://deb.debian.org/debian/dists/buster-updates/InRelease  Temporary failure resolving 'deb.debian.org'
W: Some index files failed to download. They have been ignored, or old ones used instead.
root@6570a7555a37:/opt/domoticz# apt-get install curl
Building dependency tree
Reading state information... Done
E: Unable to locate package curl
Trying from outside I get nearly the same:
pi@raspberrypi:~ $ docker exec -it domoticz apt-get update
Err:1 http://security.debian.org/debian-security buster/updates InRelease
Err:2 http://deb.debian.org/debian buster InRelease
pi@raspberrypi:~ $
Trying the install Iget:
pi@raspberrypi:~ $ docker exec -it domoticz apt-get install curl
pi@raspberrypi:~ $
So, how can I install it?
I am no docker specialist but a search came to this: https://stackoverflow.com/questions/248 ... date-fails
PVuser
Post by PVuser »
I found this link also, and tried it, but it doesn't help. There is always the same error.
I miss some basic commands like ping, ssh, curl,.. perhaps it's a bad image/container and I have to ask in a docker forum for it.
But thanks for trying to help
EddyG
Post by EddyG »
Perhaps you could try an other image: https://hub.docker.com/r/linuxserver/domoticz
OR do
docker exec -it <container name> /bin/bash
In the container do a
apt-get update
You will lose curl after an update of the container.
PVuser
Post by PVuser »
Thanks @EddyG for your suggestion. The first would be a solution, but I fear the installation on my running system for now. The second doesn't work.
My solution is now to do it in Node-Red and send the values via MQTT to Domoticz.
