Python Plugin / Managed Counter device
Posted: Tuesday 22 June 2021 9:46
by breizhcat
Hello!
I'm trying to implement my own plugin. To achieve my needs, I would like to have a managed counter.
It works fine but I'm currently not able to add a divider when I create my device.
Domoticz.Device(Name= 'Device Name', Unit=DEVICE_ODOMETER, Type=243, Subtype=33, Switchtype=3,
Options={'AddjValue2': 1000, 'ValueQuantity': 'Kilometers', 'ValueUnits': 'Km', 'AddDBLogEntry' : 'true', 'DisableLogAutoUpdate' : 'true'},
Image=Images[IMAGE_DEVICE_ODO].ID, Description='Distance driven', Used=1).Create()
My device is well created. Quantity and units are loaded, history is loaded but ... the divider (AddjValue2 it seems) is not loaded.
Is there a way to create a device with the correct divider value?
Thanks for your help.
Have a good day.
Re: Python Plugin / Managed Counter device
Posted: Tuesday 22 June 2021 10:40
by pipiche
removing the comment as it doesn't address the question
Posted: Tuesday 22 June 2021 11:30
by azonneveld
Not an answer to your question, but please change "Distance drived" to "Distance driven"
Posted: Tuesday 22 June 2021 13:59
by breizhcat
azonneveld wrote: Tuesday 22 June 2021 11:30
Yes ! Thanks
Posted: Saturday 31 December 2022 20:15
by RedEarth
breizhcat wrote: Tuesday 22 June 2021 9:46
Hello!
Have a good day.
Did you ever find a solution to this? I've encountered the same problem with a plugin that I'm trying to create that requires managed counter devices with Counter Divider set to 1000 but it's ignoring AddjValue2 for me too...
Domoticz.Device(Name="elecUnitCost", Unit=self.elecUnitCost, Type=243, Subtype=33, Switchtype=3, Options={'AddjValue2': 1000, 'ValueQuantity': 'cost', 'ValueUnits': 'p/kWh'}, Used=1).Create()
I'm not sure whether or not this syntax is correct for specifying the device options?
Posted: Sunday 01 January 2023 14:00
by waltervl
Are you sure you want to use a managed counter in your plugin? As it has no build in history function so you also have to program it yourself....
Posted: Sunday 01 January 2023 15:18
by RedEarth
waltervl wrote: Sunday 01 January 2023 14:00
Yes the API I'm using effectively presents the smart meter data as 'history' (i.e. a list of values with accompanying timestamps), the newest available data is always at least 24 hours old, so managed counter seems to be the best fit.
